where in Canada are you getting them 10 'cheap' ?
Toronto.
Toronto.
I know these are a good quality box, i just would like to see a full review. I am still going to buy this regardless.
Not sure how to sell this box with zero reviews. Makes me think that there are issues with it.
I do not have a problem buying this but new boxes have growing pains. Bugs need to be worked out. I still cannot find a review on this box yet.
Okay as they have been here for 2 weeks. Will see what happens.
For these remotes after looking a bit more i see them for 15.00 Canadian.
Will ask again on this as I am pretty set on buying this but can't find any reviews yet.
Okay since they are cheap in Canada i do not mind spending a 160.00 for this.This box has been available for almost 1.5 weeks here.
The remotes are only 20.00 i believe.
I am sure more than a few people have one of these by now. Let me know you thoughts on this box.
For people who have this box how do you like it. I have the Z8 which works pretty well. I am interested in buying this & would like to know what you think. I know it is new so there could possibly be some bugs.
Depends where you are located the exchange and shipping cost, if any. For me it was much cheaper to by from Dreamlink than amazon.com or amazon.ca.
If you are a wholesaler for large quantity these are 100.00 US. This is incorrect it is 129.99 US for 35 pieces plus. The 100.00 is for the Z8 pro.
I can get it locally for 160.00
I have the Z8 so i like to know how the GTV has a better picture quality on the streams, as most are only 720P. Very few services are using 1080I.
I don't selling point on this.
Okay as i am selling this but just curious.
When will updates end on this box?
My external hard drive never filled up. I now have the Z8 the guide is a lot nicer same as the menus. Not bashing the Z7+ but a nice change to the z8.
Turning off time shift seems to work. Since I have not used time shift for a long time not sure why it fills up if I do not use it when it is enabled
Turned off time shift which I do not use for now seems to work not filling up the card
I have turned shift time off will see if this keeps on filling up.
Not sure what to say at this point. Kind of useless to have an SD card that keeps on filling up with nothing.
I do not use time shift haven't for a long time.
I have formatted this card many times. I cannot be the only person with this issue.
It has been doing this for 2 year's.
Yes it is still filling up with nothing. I do not understand why
I have asked this before and never received a proper explanation. I have a 64GB sd card that fills up with nothing on it. I have formatted this with rufus many times. But it fills up with nothing all of the time.
I have a 4.00 hdmi cable and mine always stays on 2160p.I do not use standby mode I just turn it off.
I knew something was up. Glad they fixed it.
Something has happen as I am getting the same. Never had this happen before.
Okay that worked I thought i had tried that before but now I am not sure . I thought hard wired would be faster but not in this case getting maximum WI fi speed with my dongle. Okay thanks I KNOW better to restart after certain set ups.
I have not tried this before 1 dongle that came with the unit & another one that I bought.
2 different usb dongles. But I cannot enable the wi fi settings no matter what I do.
Disable ethernet, does it at least try to connect to your wifi?
Factory reset if none of the above works.
I have tried both still does not work. Looks like something is wrong with the software.
I have done a factory reset that did not work. I have tried 2 different wi fi hubs. Disable ethernet in settings?
Any input on this would be helpful.
I cannot seem to enable wifi it turns on for a split second but keeps reverting back to disabled.
Not sure how rufus format makes this problem go away but it has. Not sure why windows 10 format kept on giving me this error.
Okay for now seems to work will see what happens with future upgrades.
