Think he might be wondering if it's going to keep getting the security updates or is this box abandoned now . If that's the case seams bad since the shield is still getting updates.
Posts by stewlk
I think they rushed the z12 out. I've returned mine and gone back to the pro max
Any chance the mini will get a new Android.
I have mine powering off the Nvidia shield. No issues
Maybe contact the company you got it from and return it
Does Stremio work when you change from Adaptive Mode to DV or HDR only? Please try.
When I've tried. If I set it to what it needs to be then it's fine . If it's on adaptive it doesn't work
I have issues with Stremio on the Z12.
Every time I attempt to play things that play quite nicely on Nvidia, the box reboots.
It will eventually play but it's not great.
It's a switching issue which is yet to be fixed my box may get returned and back to Nvidia if it's not sorted soon
Stremio is also installed and working well...so far.
It's connected to a Denon AVRX2200 Amp and into a TCL 845 65 inch TV.
Is your box switching when plaing DV and HDR stuff on stremio
Today i turned it on.
Vpn connected, google play store no connection?
Am i sit here with my ict certificate/license/degree and those problems😂😂😂😂
Seems to be a few issues with the box at the mo. I've had that on and off .
I haven't looked more into this yet, but I think H.265 is (part of) the problem.
It's very random. Sometimes it switches to dv and sometimes it doesn't. If it does it either shows a black screen orbit just doesn't play but you can skip forward but it doesn't play. If you manually set it then it plays
Thanks, could you also let us know the brand/model of your TV?
Hi it's a Phillips the one 55inch
please reproduce the issue, and send logs. Let me know the tracking number for the logs.
Tracking # :0000001FEEC96
Reproduce as in takesl a video of it doing it or something else. And where do I upload it to
Z12 Ultra will not play HDR and Dolby Vision streaming from a Win 11 computer. Video doesn't start. FF 30 seconds just show a freezed picture. Known problem?
The box has a switching issue. Try manually setting it to dv or HDR or hlg. It will play fine. Switching automatically causing issues
Ok, thank you for the Information`s, i will forward this directly to Formuler.
I've the same issue. If I manually set the display mode and not let it switch itself it works fine. But if it's set to adaptive it gets confused. Sometimes it locks the box up completely and needs turning of and on again . This was tested with Plex , stremio and syncler.
I'm currently in contact with a Formuler employee, and the problem is being looked into. I have three Z12 Ultras myself, all three with the same problem.
Hope this issue gets sorted soon or it will be returned. Apart from the switching issue I can't find any other faults
Think the tenda u12 has issues. If I reboot my box I have to unplug the device for it to find any WiFi
Yes. Please test it out. The sample we purchased was working, so you shouldn't have any issues.
Just to update you guys tenda u12 is now working
Thank you, i`ll try it after work.
Annoucement and Release Notes:
https://www.formuler.tv/single-post/20…Z-Series-Updatefingers crossed the tenda u12 drivers work
Wired on this box is crap . Try with static IP if that doesn't help use WiFi
I bought one and it died within a week. Probably best to try it on a pc and see if it's picked up. If not it's duff like mine. Get a refund and wait for the next update as it should have the tenda u12 drivers installed
As we will have updated the 8812AU drivers, this adapter may work when the official firmware update is released.
A beta was released today does this include the drivers. As I've tried it and WiFi wont turn on with it in
I spotted that last night
Your not meant to share that information
My red beta has gone aswell. Was told to log a ticket to join beta but apparently beta is full. I want my beta back 😫😫😫
Great work . Wasn't a wasted buy after all. Thank you
ridiculous
you can get a 5ghz wifi adaptor, i bought a w3 dreamlink one but it failed within a week. the formuler team are looking into get the new TENDA U12 working,
Best idea you've had all day. I gave up trying to install it. Lol. Thanks for your help.
The content cannot be displayed because it is no longer available. The content cannot be displayed because it is no longer available. The content cannot be displayed because it is no longer available. not sure if this will help as im struggling to install the driver
Its arrived. I've Linux mint 19 installed but it's not installed it needs the driver. I've no idea how to install it
When it comes I'll update you. Should be here today
i have one of these on the way since i saw the update , i`ve messaged an admin to see if i can help getting it working,
The engineers added the drivers, but we don't have this adapter at our offices, so there was no way to test if it works or not.
We were hoping it would just work without issues, but it seems that there needs to be some extra intervention to get the adapter to function properly.
If you have a linux machine and can provide the lsusb output when the adapter is plugged in, it could help us narrow down the issue.
Otherwise, we would need someone to mail us their adapter to look into it into more detail.
i have linux , when i arrives i`ll be able to help you out, how do i find this lsusb output ?
i bought the dreamlink w2 and it died within a week so i`ve bought the tenda u12 since its added on the latest update , hope it works
Is this something that we might see soon? I get that timeshifting content that's 4k is probably beyond the capabilities of the hardware, but most of the IPTV content is 1080p or less anyway. Could the system be coded to allow for timeshifting based on the resolution of the content rather than the resolution of the connected TV?
Asking because I get a much smoother experience when I have the resolution set to 4k. It's still lower resolution content so the picture isn't any different, but in any of the sub-4k resolutions I get occasional stutter in picture, especially when the camera pans horizontally. I don't know if it's my TV or the Z7+ tho. I've tried the various refresh rates and it doesn't seem to make a difference, but in 4k the problem disappears.
Anyway, I hate having to choose between timeshifting and a good viewing experience.
I have a 4k tv with a z7+ box, while watching sport i see it stuttering while the ball is moving, i`m guessing this is due the the upscalling,
Display More
I received the USB3 adaptor today. Purchased for £7.99 from Amazon (https://www.amazon.co.uk/gp/product/B01DDRVM2Q).
I only watched the England match this evening, so it's too early to form an opinion if it has improved things.
Although I didn't get any buffering on TSN throughout the match but on other channels I had the odd buffering/loading.
Note: I also updated the software to the latest formuler beta earlier so maybe those 'bug fixes and general improvements' may help!
For me, the main test will be at the weekend to see how the Sky F1 channels hold up.
i`m after a usb adapter, is this a good one to buy ?
I have both mag and m3u, The way VOD is sorted on M3U isnt as good as it is on MAG, only a small issue but the reason i use it is coz of flexibility
