Is there a planning for the next update?
Yes, they are hard working on the next update. But no date yet...
Is known already and devs. informed.
Yesterday before diner i setup a recording. Serie of 45 minutes.
Hdmi cec is always off.
I saw it started recording. So i only turn off tv and box stays on. went downstairs for diner.
Came back and recording was stopped after 4 minutes.
Next time i leave tv on and check again.
Any news regarding update to finally add Deinterlacing?
Thanks.
Thanks.
Not so far i know unfortunately
Thank you Lucky13
I don't have much time left to return the device, so need it fixed soon 😭
Thank you Lucky13
If you can't wait, just sent it back.
See formuler forum whem update is arrived and then order Z12 again? Maby is that an option for you.
Thank you, good point!
I returned mine, to many bugs.
I increasingly noted an increase in switching channels time (fast zapping in last viewed channels) running into several seconds on my z12,i returned to my z11 and the switching is much faster (msec)
Did anyone else also noticed this?
No News regarding a new firmware update?😭 Need deinterlacing so badly
Very disapointing. ![]()
Very disapointing.
True. Everybody told me "if you don't want to have problems buy a Formuler device" and now I am sitting here without a fully working device.
Please guys. We so badly need an update to fix deinterlacing!
See here guys:
Thank you!
Writing in more threads and pushing will not help to get faster update! All bugs are reported and devs. working on fixes, please be patient until the updates comes. It is in each interest to get stable working update and this need time.
I increasingly noted an increase in switching channels time (fast zapping in last viewed channels) running into several seconds on my z12,i returned to my z11 and the switching is much faster (msec)Did anyone else also noticed this?
Yes, my Z11 pro max is much faster when switching channels
I think they rushed the z12 out. I've returned mine and gone back to the pro max
Ik have the z12 now 3 days and Its connected to a Samsung tv only with Hdmi and via a wifi connection. .
No problems untill now.
Is it possible to choose channel at start up at?
Yes,when you turn off to go to sleep,choose last channel viewed,and put the box on standby.You have to set mol3 as startup app,and in the morning at start of box this channel will be starting live tv
What is it and where do I find it?
Setting up mol3 as starting app you do so in launcher settings.
When you watch a number of channels after each other,you can go by short press back button,to an overview of last watched channels,you can choose in there the last channel viewed,and put your box to standby/turn off.the next day when you start your box,the last viewed channel,will be your starting live channel![]()
Please check the profile 7 file again with the new beta.
Access Code: 1339
1. Open the Software Update app
2. Enter the appropriate access code, then press the red box button
3. Start Download
Let me konw your results.
Just tried the beta. Profile 7 files are now just playing as plain hdr (not dv)
Yes, that is the intended fix.
Previously profile 7 files ended up in black screen.
Other boxes (like nvidia shield) also converts the profile 7 files to HDR.
Access Code: 1339
3. Start Download
Hello.
Thank you for the update and the work.
Unfortunately, I returned the box a long time ago.
But I see that you received another response, so that's something already ![]()
If the passthrough for HD audio formats is hardcoded into the firmware (we can dream :p), maybe I'll buy it again one day, but if not, I'll pass on this generation.
At least stremio plays nicely now with Beta firmware, no juddering or skipping
👌🏻💪🏻 i thougt it was just busy. Check again today. Thanks.
I take it back, it still stutters..
Try small movies. Between 4gb and 1gb.
How higher the gb, how slower they load. So much people that it use. It’s to slow and to many users
In stremio I can watch a programme with a small file size, say 180mb and it jumps and stutters all the way through.
I use Debrid service so there are very short if any loading times, it just won't play certain files where Nvidi shield will.
I then tried a 4k HDR movie at 19gb and it loaded and played fine
Do you use a VPN on the box? I do the same as you and have no issues with large movies streaming via streamio.. You can DM what you're trying and I can test.
Try streaming an old series called
Out of town with Jack Hargreaves.
It's the same with or without vpn
I would like to take a moment to say thank you.
I can now enjoy all streaming portals such as Prime Video, Apple TV, Paramount+ and Disney+ in Dolby Vision and Atmos.
Thank you very much for the update.
So nothing is “cached” on the debrid or torbox services. You’ll need to wait until it’s on their server before it can stream smooth.
It's on the Debrid server that I use.
It loads instantly but stutters all the way through.
Same thing on Nvidia works perfectly
VERY dissapointed about missing fix for this error! ![]()
Ive had to revert back to Nvidia shield for most things
So I’ve had my z12 ultra the last few weeks and love it. Such a huge upgrade from my 4k max Firestick.
One question though, my weather app works but gives me some random location. I live in London uk so how do I get it to display the proper town rather than some random place. I don’t have a vpn at the moment although I have a subscription with NordVPN so will probably install that soon.
Thanks.
I have nordvpn as well,for UK you can choose 4 cities (including London),this should make your weather app more reliable.
Ok I will try that and see if that works. I have it on my iPhone and have it set to London uk and it works perfectly fine
Thank you for the reply
Thanks.
Getting the exact location is difficult.
We're looking into imporiving the accuracy on the weather widget.
