Thank you for replying
This is happening with different movies.
my IPTV provider connection is MAC ID/Stalker and url.
someone in another older post with same issue was suggested to "Try setting AFR for VOD to ON".
Would that really help?
You can try yes to turn on/off afr for vod and see if it helps.
Should be great if it helps.
But afr is beginning to work at the beginning of movie instantly.
It's worth a try.
If not work,
You can also ask provider to convert your stalker id to xc api. (Url, username and password)
It's has much more functions and better performance.
Btw... stalker/macid is by some providers not in work anymore.
Only xtream codes api.
Try that also please.
First the afr option what someone say.
If that not worked out for you, turn it back on and then you can try to contact provider to "convert" your subscription to xc api.
I think it will work better. Also you can watch programs back if provider supports it etc.
Goodday my friend
