how to watch netflix on formuler z11?
Netflix
- Z11 Pro MAX-BT1
- Apps
andre09 -
June 11, 2025 at 11:23 PM
Is not possible. Formuler didnt get a certifiy from netflix
Netflix certified only tv's and a very small amount of boxes.
Netflix you should watch on your own tv. Every tv has netflix last years.
He can watch Netflix on Z11 but only with mobile version steering with mouse at SD quality. Install the version from Market.
For Android Version with HD and 4k, Formuler do not have certificate from Netflix.
Is it possible to get this certificate?
I’m sure the box is powerful enough and supports it codec.
I vaguelly remember that Netflix has unreasonable criteria to get it certified (something like 1000000 boxes sold)
However i also have a cheap Chinese box where Netflix is certified,unfortunately for the Z11 its not.
Its for none formuler supported.
The should do it fast, they are the best boxes.
I use it like this.
Works fine for me.
It is a bit annoying you have to use the cursor to navigate through Netflix.
most of the times I first look on my phone and pick what I would like to watch....then find it on the mobile version app on the box
I guess most people really do use formuler for iptv mainly having access to much more than what is on netflix already and because of that obtaining a netflix license is not interesting for them. That is how i see it now
Maybe with cracked key and without real certificate
If you try to get official certificate, you must pay like crazy and full-fill all expectations from Netflix. 4K Netflix content is for the Box like Z11 no problem.
Maybe you are right,but on my chinese box i have speed dials for netflix,prime video and youtube.I have a regular subscription for netflix,so i also have it on my SONY smart tv.
Maybe the shear number of chinese boxes make them eligble for Certificate
That you have to pay for certification is bad, you have made a proper box and then they try to make you pay them while it should be the other way around! They should be happy that many boxes uses them.
I agree full with you and do not understand Netflix at all. Cracked keys on cheap boxes -> Netflix do not care because its China, but would Formuler do the same in Korea then the lawyers would knock next day on door. Some moves are just not fair, because Formuler tried very much to get the cert. but the expectations from Netflix are exorbitant.
I am still really wondering how something simple as Netflix isnt able to run on the Formuler Z11,
Ask netflix why they don't certified most boxes.
It's stupid also, less costumers. Why not netflix on all devices? More buying customers is better.
I wonder, netlfix app should be able the run fine on any android OS right? How come they can block some devices? would think its just a progam for a certain operation system, Formuler runs on Android right?
Simple explained: netflix doesn't certified the formuler boxes.
Even the formuler gtv with original androidTV software didn't have netflix. But the gtv is google certified.
It's a netflix thing. They don't give formuler and many other brand boxes no certification.
