what about menu option to "add minutes to begining/end of recordings??
In formuler Z9 for another 150€ more.
You call an update a few fixes ?
And what about a "free recording" feature where we can enter start/end time of the recording ?
We're waiting for months...
Of course no "free recording" (with time and not epg).
Z7+ is dead.
Thanks for your answer, we all notice the care of customers.
I'm sure there won't be Z7+ updates anymore.
But you be sure I won't order another product again.
Could you add a little fix in the next Z7+ MOL update (if you intend to keep your material updated...) :
When I'm in VOD menu and I want to switch to TV series menu I have to cope back to live channels before long pressing VOD button to access Series.
Is it possible to long press VOD button from VOD menu to directly access Series ?
Same from Series menu, please allow pressing VOD button to directly access VOD without going back to live channels.
Simple isn't it ? so please show your customers their Z7+ is still updated.
And also don't forget to add free recording without EPG as you said you'll add it.
Thanks.
Salut Kole ! ![]()
Of course I tried the add-on : 540p max resolution.
You will not get any better that sd as this device does not meet currentl security requirements by google to have hd running on Netflix at the moment
But... I thought the main interest of the Netflix addon was to provide 1080p by using Kodi 18 (and its DRM support to cheat the Netflix drm check).
If it's not the case there's absolutely no benefit to use this addon instead of official app.
Thanks Ian, I'm waiting for your release as what I tried is not very reliable. I noticed I had 540p max now....
Please not I had absolutely no problem on my Windows 10 PC to install that add-on.
Nice Danny it's more easy that way.
For the Netflix addon I finally get it to work... sometimes....
I mean sometimes it works using the Kodi 32 bits RC version and the custom ESN.
And after a reboot once again no video are playing.
Thanks for your answer and your help.
Still doesn't work, I opened a dedicated topic here if you have some informations :
Thanks.
Hi !
I tried to install Netflix add-on in vain...
Tried with the Nightly 64 bits version (didn't install), then with 32 bits nightly, RC5, and even official beta from Playstore.
Everytime I have access to Netflix account with all contents but when I tried to launch a video it tries to start then immediatly stops.
I also tried changing the ESN with Ians325's help : NETFLIX KODI ADDON ESN
But no way, I'm in deadend.
If someone wants to try...
This should help you : https://forum.kodi.tv/showthread.php?tid=329767
I'm actually trying to install on Z7+.
Addon installed (32 bits nightly) , inputstream adaptive enabled (with default options).
I have access to content but no way to play a video, I let the default ESN :
NFANDROID2-PRV-T-L3-HISILICONZ7=PLUS
Please help me I don't see what's wrong.
I finally managed to get the Formuler remote usable.
When first installing you get asked to configure the new controller.
To enter that you have to use the Air sync remote Z app, and shake tour phone to get air mouse.
Then you can sélect "yes".
You're now into the xbox 360 controller config, just map the 4 directionnal keys , the A button with the OK key of the remote., the B button with the "Back" button of the remote.
Then you can install keymap editor to map all the other keys.
I try Netflix addon tomorrow. Sorry for my poor english.
Strangest thing is that the left part of Kodi homepage works with the Android "Air sync remote Z" but no way to launch an addon.
That's a pity cause the Netflix addon could propose HD content for the Formuler.
Someone managed to get a working Kodi 18 (RC5)?
I've got remote issue, keys are not recognized.
If yes anyone could run Netflix Kodi addon ?
Thanks.
Thanks.
Problem solved with my provider.
Very strange issue today.
When I try to access the portal of my favorite IPTV provider I've got a message "Your account is blocked or has expired. Please contact your services provider".
But it is ok with Stbemu using the same MAC address so my account is ok.
MyTVonline is also ok with another IPTV service using the same MAC address.
So I really can't understand what's going on !
I try with 1.9.24,1.9.54,1.9.59 versions of MyTVonline, in vain...
Could you please help me ? Thanks.
Since v.1.9.48 I can see "EPG loading" in top right corner of the screen when starting MyTVonline.
But unfortunately with one of my provider it takes more than 30 seconds to load EPG and during this time no way to change channel : I can select it but it won't appear until EPG update has finished.
EDIT : SOLVED WITH BETA 1.9.49.
Keep going your excellent update and please :
- Add free recording based on time and not EPG (and allow to add some extra time on EPG recording)
On the recording update part can we add minutes to start/end of epg recordings??
Unfortunately no !
I hope this crucial feature will be added soon.
Hi, it's in my humble opinion the most important feature tu add to MyTVonline : a real free timer recording when we can manually set star and end time of each recording.
Hope developpers will hear us.
Hi, try to install Stbemu to check if you can access portal with it.
Hi, you're right, seems ok with 2 others IPTV portals.
Certainly because of the classification of the files.
Thanks.
Hi, my former provider unlocked my MAC address when I kindly asked him.
Please note it'll take about 1 day after you can use MyTVonline with the same IPTV portal.
I've got a problem related to this post.
I subscribed to an IPTV panel with Seller A.
After the subcription period is over I found another seller (let's call him seller B) and as he was offering the same exact panel cheaper I decide to go with him.
First he couldn't activate his panel as my MAC was used by Seller A.
I contacted seller A who unlock that and then seller B could activate his panel.
All seemed ok except now there's no way to use MyTVonline with this portal. It refuses to connect.
And the strangest thing is that I can connect using Stbemu on my Z7+.
But I want to use MyTVonline ! Much better app...
Of course I tried a lot of things :
- MyTVonline is ok with 2 other portals.
- I factory reset the Z7+
I really don't understand. Any help will be appreciated.
Thanks.
Regards.
EDIT : PROBLEM SOLVED BY ITSELF. MUST BE TO LATENCY BETWEEN THE UNSUBSCRIPTION AND THE CONFIRMATION.
Hi Inspecta,
If buffering only occurs every minute or so it's a bit différent than other issue where it buffers egery 5/10 seconds.
Have you tried to expand buffer size in options ?
Do you use ethernet cable instead of WiFi ?
All I can say is Kodi 17.6 is ok here. Absolutely no weird sound.
If it's possible Ethernet is always the better choice, often faster and more stable.
I advice you to assign a static IP address to your Formuler.
I can't get filters (green button on VOD/TV Series list) to work.
When I try to filter by first letter or by year I always get a "No result found" message.
Could you please report this bug to devs ?
Thanks.
I'm sorry to create a new topic but I didn't see the same issue described before, please note my IPTV service is activated with MAC adress and I have no EPG issue with other apps like STBemu :
- when I'm watching a channel, sometimes EPG doesn't display at all or is at the wrong time.
- so I try to press the EPG button at the center of the remote to access the EPG grid. And I can see "No information" (so it's why EPG didn't appear when I press OK to access channel list) or it's 2 hours earlier program (I live in a place with +2 hours with original EPG)
But.....
When I'm on the channel list (by pressing ok when watching a channel) then press right to access the second EPG menu (the list one not the grid one) all is ok
Time is good, EPG is Good...
My question is why is there 2 differents EPG ? And why the EPG display on the channel list is based on the wrong one.
Thanks for your help, not sure my explanation is clear ! ![]()
Of course I tried UTC setting for EPG and it's even worse cause the EPG that was good is now at the wrong time.
Edit : in fact I have 3 IPTV providers and the problem occurs only with one (the one I use daily).
Please note that I have no problem using others apps like Stbemu or IPTV Smarters.
Thanks for the suggestion.
We will carefully consider this request and try to apply it if a consensus can be found.
Maybe we can add a "Don't show this again" checkbox so users can decide for themselves if they want to see the popup or not?
Yes "don't show this again" would be great or at least put the default answer to "ok" instead of "cancel".
Thanks.
Hi !
I don't know if I'm the only one but everytime I'm exiting a VOD content, or simply VOD menu, MyTVonline asks me if I really want to exit.
Of course I want ! ![]()
More annoying during this confirmation, highlighted answer is to cancel, so I have to press left to go on "ok" then press "ok".
Is it possible to cancel this confirmation or enable that in option menu.
Clicking one time instead of 3 is more convenient.
Thanks.
Best regards.
Any news about custom launcher ? I just received my Z7+ today and even if I'm very pleased with it I'd like to use my own launcher (TV launcher Pro2) and add meteo widgets.
Thanks.
