Can anyone tell me what the "VIME" setting is on the android RC app and whats it used for?? (see attached).
Much obliged.
Much obliged.
Ok, thanks everyone. Problem solved.
AS I mentioned, the keyboard settings caused the problem inputing the PIN.
Actually, when I tried inputting the PIN code with the android Z8 remote app it worked, but the PIN code "0000" does not work with the formulerZ8 RCU. Maybe because I have keyboard set to VirtualME?
WTF is VirtualME??
I am trying to modify startup app setting but keep encountering the following problems:
Can someone advise me on how to resolve these two issues? Are the only option's a factory or software data reset to resolve this?
Thank you.
Display MoreNew official update released for Z8 and MOL 2.
Firmware Version : 1.4.53
MYTVOnline 2 : 7.6.3
WARNING:
Install and use at your own risk. Software cannot be rolled back after installation.If serious errors occur, please do factory reset.
The install process and reboot works automatically! Please don`t turn off the box or unplug the power supply, could damage the box. The reboot after update needs always much more time then usual, please be patinate and let the box finish the install.
Fixes & Improvements:
- ADD: Mount Network Attached Storage (NAS)
- Access from the new home screen widget
- ADD: Launcher notification icons for VPN, USB storage, NAS storage
- IMP: Android Security Patch Level Update: November 2019
- FIX: Temp fix for Disney+ app crash issue on vertical scroll
- Press CH UP/DOWN to scroll up and down inside the app
- FIX: IPv6 ON/OFF bug
- FIX: OK button in Automatic Shutdown menu
- Crash fixes
- Bug fixes and performance enhancements
New Features:
- ADD: VOD Favorites
- Press and hold OK to toggle favorites
- ADD: VOD History
- ADD: VOD Resume playback
- ADD: PiP Swap
- Press and hold RED hotkey to swap.
- Information: PiP is only possible with one sub and two active lines, on XC Api Portal + M3U Playlist. Mac/ID Stalker doesn`t have PiP!
- ADD: API Portal > VOD Sort
- ADD: Refresh contents lists
- Main Menu > Refresh
- ADD: Receive portal messages
- IMP: VOD seek bar
- FIX: Parental PIN gets reset
- FIX: Scheduled recording records a different channel
- FIX: RTP URL playback issue
- FIX: Cannot play certain VOD formats
- FIX: Missing Trailer button in API portal
- FIX: m3u grouping issue with certain list formats
- FIX: Channel group issue after going to previous channel
- FIX: EPG stops working after waking up from Standby mode
- FIX: Cloud TS wrong channel playback issue
- FIX: Crash fixes
Extended Infos:
ADD: Launcher notification icons for VPN, USB storage, NAS storage. Please see picture.
Please read how to -> How to set Z8 and NAS for recording and timeshift over network.
hello.
What are the remote control inputs/commands to operate the functions (if any) of the PIP feature? Or, is PIP on there, stuck in the top right corner in static fashion with no options available?
Thanks in advance.
Settings-/Network-/IP Settings-/Static: enter your local IP address, Gateway (router IP), network prefix length: 24, DNS 1: and DNS 2. Looks like Z8 boxes are set to google DNS by default.
Agreed...the vpn will get you around the ip ban temporarily until your provider unbans you.
No wrong,...you will "get around" nothing until the provider resets your account. VPN use is irelevant and nothing to do with the equation.
That's Great question. The vpn hides your IP making it difficult for the provider to block.
I sure hope someone who understands the situation and the technology can respond.
well, yeah, but the vpn IP gets banned as well. I dont think using a vpn has any impact or relation to these so called IP flood bans. They are a function of excessive epg requests from the device.
It's a good idea to subscribe to a VPN service just in case.
are u saying a vpn can eliminate IP flood ban problems?
Well it’s quite simple.... rather than changing this that and the other... Cloudflare provide an app for said device which can be turned off and on at leisure as well as automatically coming on until it’s turned off. In turn that app creates a VPN profile, it clearly doesn’t mean it’s a VPN but it creates the profile all the same.
Throughout multiple posts within this forum the 1.1.1.1 app is recommended.
I actually used it when it first came out and rate it highly.
Read this about cloudflare and other DNS providers. (if you're concerned with privacy and security)
Thanks UN....already done that. It’s connected via Ethernet with a CAT6. If I do put it on WiFi it’s 5G and I’ve got a WiFi analyzer and it’s on a channel no one else is.
Hers's the issue: some devices/many devices like and dislike certain 5G channels...a macbook is a good example where 5G channel 149/161 etc show one or two wifi strength bars but show five wifi bars when I switch to channel 36 or 40. Perhaps the wifi card on your device performs better on different 5G channels. Tty it out...change the wifi channels on your router and check the wifi strength meter. Not sure what device you are using, but the Z8 has gigabit ethernet and u probably are better off using it to connect with vs wifi if you cannot maximize the 5G signal strength.
Using 2 or 5G? If 5G, check what channel u r using and perhaps change the wifi channel. That may change things with the connection strength.
I have Express VPN on the box and also already downloaded cloudflares 1.1.1.1 app.
Problem I described is you can’t use both apps at the same time as the box won’t allow it due to cloudflare requiring a VPN profile and also Express VPN requiring the same.
I was hoping the Formuler z8 would allow multiple VPN profiles but seems not the case.
Why on earth would u want two vpn's at the same time...lol!!
Cloudflare is NOT even a vpn but merely a DNS resolver. If you want... change the DNS on the Z8 to cloudflare or better yet use Quad9-(9.9.9.9/149.112.112.112)....way better privacy with them and just as fast.
Just change off porn before your leave the app
If I want you to bark, I'll pull your chain tube-steak.
Changed vpn protocol to tcp and connected to a new server.... Working spot on
what vpn are u using?
On the update screen, just press "0227", and the Beta message will appear in lower right corner of screen. There's no obvious place to enter the numbers...just press the code.
ohhhhhh......use the damn flippin keypad and type in 0227.....
of course....i should have know all this!
LoL....
thanks a lot big BIllC
I am new to Z8 and ask for assistance to find and change settings in MOL2 to prevent automatically conecting to last live TV that was playing. This happens as soon as I click on MOL2 app on the main screen. Is there a setting that can be set to prevent this from happening?
Thanks in advance.
Display MoreFormuler Z-Series beta hotfix released for Z8
Firmware Version : 1.4.25 BETA HOTFIX
MYTVOnline 2 : 7.2.3 BETA HOTFIX
WARNING:
HowTo Install:
Home Menu -> Software Update -> press "0227" -> Red Icon and Beta Test SW appear (right corner) -> Press Red Button -> Now is the Firmware and Software shown, press now "OK" button for install.
The install process and reboot works automatically! Please don`t turn off the box or plug out the power supply, could damage the box. The reboot after update needs always much more time then usual, please be patinate and let the box finish the install.
This time also, we get many changes and top new features. The biggest is: Backup & Restore (no more fear from factory reset
), USB DVB-T2 tuner support, Recording Manager and much more.
Many user requests are implemented and bugs fixed
Please note, not all user requests can be implemented so fast, if not in this update, if possible it will come with future updates, step by step.
Change Log:
- [MOL2] FIX: USB Timeshift bug
- [MOL2] FIX: Random crash while viewing Single EPG or Classic List
- [MOL2] FIX: Black screen appears under certain circumstances
- General bug fixes and improvements
Important info about [MOL2] FIX: Black screen appears under certain circumstances.
The fix for the black screen issue was only for a certain case that devs. reproduced in the lab. Please don`t mix this fix with ISP or IP ban issue and from ban following black screen.
I have checked Software Update on my Z8 and this hot-fix update is not shown or available on my box...why is that?
My current firmware is v1.4.22, IPTV version is v7.2.2.
forrmuler box's are not desidned for a vpn...install a vpn on your router!
Just bought the box 😂.... Wish I hadn't bothered.... You need to fix this formuler
agreed. There is no excuse for this cock-up!
Ok everything has now started working again by itself.
I did not have to re-enter the Api or m3u details. The old details have just started working again
Yes, it has started working now....strange but good.
Hello guys,
also had contact with the support of XE.
Please delete your M3U playlist in MOL2 and create it again completely. Just like before.
I did not have a typo in my playlist but since the weekend the playlist did not work anymore. For whatever reason.
But as I said once completely deleted and re-created and I can connect again via MOL2 with the XE M3U!
U refer to m3u lists AND API lines, or just m3u list?
I have deleted both my API line, m3u list, re-entered it into xtream-editor and there is no change...they do not connect in MOL2.
But, I will try it all over again.
Thanks for your input Cob.
Working here ok in Tivimate
oh yeah....must be something on my end then...thanks!
not work
on tivimate? Cuz, yeah....xtream-editor was working on tivimate the past few hours and now poof it stopped, just like that.
Do not understand why it supposedly works for you and still does not work for me.
The XE M3U Link works for me on other players but not in MyTVOnline2.
I've bought an extra XE subscription so I can create a favorites list and sort them as I like,
while keeping the comfort of MyTVOnline2. Unfortunately, do not bring me anything anymore. Disgusting.
No, it's definately still not working with MOL2, except for a M*G line, but working okay in tivimate.
Thanks for the explanation. I'll pass
FYI, ExpressVPN have a router app which you may want to try. You can then "split tunnel" your connected devices to vpn or WAN.
Can you explain how to do this? Thanks
yes I can. But u will need a vpn capable router.
I would recommend AsusRT-AC86U flashed with Merlin f/w. This router has hardware acceleration to maximize OpenVPN speed.
Your Z8 will not be able to manage the encryption load of OpenVPN.
install ExpressVPN on your router....NOT the Z8!
It can not be a coincidence that it will not work in MOL2 and that Xtream Editor will be releasing his own X3M Player / Xtream Editor Player at the same time.
yes, this entire debacle comes across as being somewhat suspicious. When I sent a suport ticket to xtream-editor they told me to use this new X3M player and then they went silent.
well, maybe its not a problem with Xe as the api lines work in tivimate when I tried earlier today.
Maybe xtream-editor wants all MOL2 users to abandon m3u and API lines and pay for their M*g device option.
Yeah, it is strange. The folks at Xe have gone silent since I started this same discussion with them.
I just set it up with a M*g line and that worked good, no issues.
Wait and see I suppose.
Thanks.
No, he use m3u playlist and not Mac or XC Api portal.
I use and follow this guide and everything worked until yesterday.
Using m3u link. As I know api lines where never supported for mol. I even asked support and they said only magg line or m3u link. So I don't know what you are on about api lines.
So, to clarify, you are using Magg line with Xe on MOL2, and not API lines?
Input these from X-e API lines, Use these to create a new connection under Playlists in MOL2
https://xtream-editor.com/en/get/m3u/XXXXXXXXXXXXXXXXXXXXXXXXXXX
https://xtream-editor.com/en/get/epg/XXXXXXXXXXXXXXXXXXXXXXXXXX
As I said, this method performed flawlessly for about 4 weeks and stopped yesterday, which I find very strange and nothing can account for this obvious anomaly.
Thanks Boss!
Interesting. U sing MAGLine?
As I said, it worked fine for me as well,....for a few weeks. Then something got discobuberated I suppose and refuses to work now.
I just tried MaGLine 12 hour trial with xtream-editor and thats working 100% well!
Just xtream-editor API lines have stopped working for me.
I am "newish" to formuler having recently purchased a Z8. All good so far....and havin some fun!
