Posts by haguewest
yeah he is right most got deleted on youtube.... there isnt alot..
Display More
So happy with my mytvonline 2 devices.
Z8 and gtv's.😃
You put on the device, and it starts mytvonline 2 and it connect to the portal and content, its direct fresh connection.
No extra work for refreshing content every time.
Why they make it manual refresh?
Why not automatic?
Why make formuler it not the same as in mytvonline and mytvonline 2?
When it connects to portal, you have direct the "new" content.
yeah. they must add it in the next update.. this should be one of the first things they should add on myonlinetv3 on the very first update. but ok.
its useless anyway, we still can adjust the subtitles.. if its not perfect on time. we cant adjust
Once you log in on the formuler box, you just select your preferred language, then once your chosen movie or show is playing you select the subtitle file from the play bar menu
that all works.. only its or to late or to early ... so useless .. i tried 15 different ones.
Opensubtitles.org
i made a account over there. and logged in with in on the formuler z11 pro max tv box. what can i do on that website
need better subtitle options..
i searched subs i got alot of them ,not one work. and i cant adjust it? so its useless.
every time i want to try a different one i have to type everything again. it wont remember what i searched... so much work and still dont work
dan heb je geen goede iptv provider, de url werkt niet
I HAVE NORD VPN aswell.. hard to set up.. i watching without it now
i feel like a beta tester with this z11 pro max... lol allmost paid 200 euro
is there a way... i can pin/check a episode of a serie that i watched.
so i know where i left the last time...
mullvad is the best... it doesn't need a account/email or anything.. like most others... so its totally privite
you even can buy a pre paid card on amazone.. so no one can track you down with a ip/account/email enz. plus its super fast. -
still not working right? its all empty for me. no epg at all ........
sounds like provider side but
1. try adjusting epg offset to compensate.
2. clear epg data and resync
3. report issue to provider.
how do i adjust the time/settings? cant find it
yep having this issue as well ... crazy to think i paid 170 euro for this box
people said its the best not even official net flix or anything
i sold my shield :P... to be a betatester for this box...
not happy with it (yet) cant send it back.unfortunately, lets hope for the best in the upcoming updates
