Posts by LyleJ
    Has anyone been able to get Projectivy to work on the Z11 Pro Max as default launcher? I know the stock launcher can be disabled using the ADB TV app. Unfortunately, you then lose access to the device Android settings. Projectivy works fine but you have to start it manually if you want to use it.
    I've also tried the Launcher Manager app but the settings won't "stick". Stock launcher still opens when restarting the device.
    I'm not able to add a content provider. I've enter the portal URL (xcapi), User ID and Password exactly as it is on my Z11 Pro Max. I keep getting the Code 1010 error. I've checked and triple checked and the login info is exactly the same.
    I have another provider that's working fine, on both.
    MyTvOnline+ Premium 1.192-1679
    Samsung Galaxy Tab S9/Android 14
    Any suggestions?
    Description:
    Thanks Sam! I know there could be many reasons the provider signal can be affected. Is there any way to determine the actual signal level (rather than 30, 60 or 90%)? Perhaps an app or diagnostic tool? I've run into this before. Simply telling a provider that I'm getting a bad signal almost always gets a response "everything is fine on our end".
    I'm troubleshooting occasional speed issues and am wondering what the 3 signal bars represent. My assumption is that it's internet speed connection but the behavior is strange.
    I'm connected with 1 gigabit Ethernet and consistently get 850-900 speeds when checking with the speed test app from the market. That's pretty close to what I see with the app from my Internet provider.
    While getting those speeds, the meter rarely shows 3 bars without a VPN. When I turn on NordVPN, I get 250-300 speeds but the meter never changes. It's usually 1 to 2 bars whether I use Nord or not.
    The behavior of the meter just seems strange.
    Are there any settings on MOL 3, other than buffer size, that I can try to help with freezing and buffering?
    I've been having a lot of issues lately and have tried so many different things, I just wanted to check if I'm missing something in MOL 3.
    I believe it's a provider issue but they keep having me try all sorts of stuff (reboot devices, try VPN, clear devices and on and on) that are not working.
    I've tried Tivimate both on my Z11 and my Android TV and have the same issues. Internet connection is consistently 800-900Mbps.
    It's frustrating that my provider seems to believe it's not an issue on their end, especially when everything points to it being so.
    Test with Cloudflare as DNS Server and report back.
    I just tried with the three DNS options (Cloudfare, Google, Quad9) and still having the same signal issue. I'm not sure how to try it without using the Z11 box. I'll need to figure that out.
    Contacted my provider again. They still say all is fine on their end. I signed up for a trial with another provider and am waiting for credentials to try it out.
    I'm not sure if this is Formuler related. Am curious if other users are having signal strength issues. I suspect it's a provider issue and have contacted them, multiple times. Naturally, they say all is fine on their side.
    I've started to have a problem with the signal for certain channels, specifically all of my 24/7 channels. The signal will have three full bars in MOL then start to drop after a few minutes. If I restart my Z11 Pro Max, the signal is three bars again but starts to drop, causing freezing/stuttering. My Z11 is connected via Ethernet and I'm getting 800-900Mbps download speeds.
    MOL 12.1.4
    Firmware 11.3.3
    I hope they eventually sync the two. So that any content watched on one updates in the other, for seamless content viewing.
    Decided today to install it. I was quite surprised there wasn't an option to sync or use the backup from my Z11. You would think that would have been a no brainier. Especially if they're trying to compete with other players.
    I'm just curious what others users do. Is there a way to copy/paste text when setting up new providers? Or maybe import a text file? I'm evaluating different providers and it's quite tedious to keep entering long URL's, especially with the remote. I have a Bluetooth keyboard but that doesn't always work.
    Thanks!
    I'm having the issue where a lot of my Live TV channels don't have program information in the EPG. This is with an Xtreme codes connection. I've refreshed the EPG and content numerous times but that doesn't fix it. I've read the article on how to setup the different connections. I've also read so many posts about this that I'm suffering from information overload :smiling_face:.
    I tried adding the MagBox url (Stalker?) they provided and entered my credentials. Selected alternate EPG (which seems to be the common solution), but when I try to connect, I keep getting an error that my account has been locked or expired. When I go back to check what I've entered, the option for alternate EPG is gone. The URL is correct though.
    After contacting my providers support, they provided an xhtml url (including the portal and my credentials) and said to enter this in the "EPG Section" manually. The only place I see that option is for setting up an M3U connection (which is a completely different url).
    Can anyone provide some clear instructions or suggestions? Before I try other providers, I wanted to see if these different ways of getting EPG information are the solution.
    Thanks!
    Respect, to all the members of the forum. I have the same problem, I did the factory settings as in the video tutorial posted there and nothing helps, the box does not wake up after 6 hours of sleep, and when I manage to start it, it works without problems (turn on/off/standby) I went to the store to return it and the seller told me that I'm not the only one who returns because of that problem, out of 10 boxes, 7 were returned to him because of the same problem and he convinced me to wait for an update, if there are no corrections then to return it. So I went back to the old Z8, which is perfect. I hope that the developers will see this problem and solve it as soon as possible. Greetings to everyone, and sorry for my English, I work through google translator.
    Thanks for this info! I've been seeing the same issue. I keep getting a message "No or Weak Signal" on my TV when I turn them both on. At first I thought it might be my connection to my receiver. Changed HDMI cables and tried different ports. Same issue.
    I then bypassed the receiver and connected the Z11 directly to the TV. Same issue.
    I also did the factory reset. It would only work if I unplugged the Z11 to restart. Unfortunately, my return window has closed. Hopefully this gets addressed in the next update.
    I'm a new Formuler Z11 Pro Max user. Is there a user guide for MYTVOnline 3? All I can seem to find are some random YouTube videos and threads on the forum. There's not even much on the helpdesk (info is mostly for MYTVOnline 2)
    It's a bit frustrating as a new user to have to search for a detailed guide. And not find much.
    Thanks!
