I have a Formuler Z12 Ultra and I'm experiencing the following problem:
When I set AFR (Automatic Frequency Range) for VOD and TV series and start playing various movies, the box crashes completely and I have to unplug it.
Is there a solution for this?
Thank you
If I disable AFR for VOD and series, the box does not crash.
On my z12 is afr on for vod and series and does not crash.
Try first to delete cache from mytvonline3 and restart box.
If that not helps make via mytvonline3 settings a backup on a usb stick. So your portal(s) and favorites are backed up.
Delete mytvonline3 and reboot box.
Install mytvonline3 via formuler update.
Go to settings and import/restore backup from usb.
And try again.
You can also try a factory reset. But that's the last option i should do.
but it can fix tour problem.
If it's not fixed after factory reset, maby your tv can't make friends with the hdmi cable so it's crash. Do you use original hdmi cable?
also try in android settings to set hdcp 2.2 to 1.4?? Just a gues.
Goodluck my friend
P.s: don't write in code please. It’s annoying. Thank you.
