when trying to update firmware i get an error message Insuuficent memory. Is there anywar i ca increase memory.
memory
- Update
- Z10 NEO
Geoffsri -
February 25, 2026 at 8:28 PM
Download memory cleaner from market app.
Open it and delete cache files.
And try to remove other apps.
Z10 neo is only for iptv.
If memory cleaner has removed all cache and you still can't update.
Do factory reset and update direct before you setup mytvonline etc
can i open the box and add memory. like a micro SD card
No, it`s mini board with soldered chips.
I have a USB drive attached . Can i install updates or apps onto this drive
No, only recording files and or apk files you can put by laptop or pc on usb and install on box memory
WHERE CAN I DOWNLOAD THE APK FILES FOR THE APP. LIKE FOR kODI, hULU , NETFLIX,
Formuler market app, google play store and search on google.
Kodi: https://mirrors.kodi.tv/releases/andro…v7a.apk?https=1
I have Downloaded the >apk files onto a USB stick. Please guide me thro. installing the apps on my Formuler Z10 Neo box
