Posts by Lucky13
    LOL Lucky, you are dreaming to much :grinning_face_with_smiling_eyes:
    In the time of ram and flash price explosion, where you need almost as manufacturer to pay for every single license big money and you wrote all sound codecs + new Motherboard and connections would be even 250 to low. This is really no joke, they would need first to sale many, many boxes to start at some point to earn money, so much are the licenses expensive.
    300 also fine. You can years forward.
    Funny, I had a server that got me 450 mbps. Had it for the longest time thanks to always on. Till the power went out.
    Vpn secures your connection and slow it down yes. Do all VPNs, But that's due encryption. Nordvpn is the number 1 vpn.
    Can we have an update on this issue?
    My formuler was updated this week but I can't find anything new regarding the remote.
    You mean "Formuler remote" app in apps section is gone?
    If yes, make backup of mytvonline3 on usb. And do factory reset my friend.
    Good luck.
    So here can Formuler throws a strike!
    Make a better device then the NVidia box.
    Install AndroidTV 14 on it.
    Let it support all Dolby audio codecs like DOLBY DIGITAL (PLUS), DTS, DTS-HD, DTS-X, DOLBY ATMOS, ATMOS THRUEHD etcetera.
    8 Gigabyte of memory and 128/256 Gigabyte internal memory, Dolby Vision on it, hmdi 2.1b, hdcp 2.6, MyTVonline3 on it and...
    ...the name of the new better box become...
    ...The Formuler GTV 2!🥳🥳🥳
    I pay if need 200 a 250 for it then. Doesn't matter. (Netflix not supported due Netflix itself, but i use it on tv)
    But, it's an idea for Formuler and a dream for me.
    But so long i keep it with my Z12 Ultra😍
    Thanks for the reply,but where can i find audio track menu option,in a tv serie?
    Simply by pressing info button,it says dts5.1 in 2nd episode it is dd5.1 in first episode.,So you are rigtht that episodes may have different audiotracks,this however does not explain the vast increase in the second episode volume level as i set in sound settings"never use surround",so audio passthrough should not occur?
    The movies and series are mosly downloaded from internet and can have different audio types.
    It's increase sound often yes.
    But if you setup "use no surround" it can use stereo sound or maby normal dolby digital 2.0 and that one can increase too i thought.
    Dolby 5.1, Dts, dts-hd, dts:x and dolby atmos, atmos thruehd are real surround sounds.
    And sometimes have some providers more audio and sub languages which you can choose.
    I have done a factory reset of the Z11, reinstalled Stremio, deleted and reinstalled all Stremio addons, linked my Premiumize and Torbox debrid accounts to the newly installed Torrentio, Comet and StreamThru Torz add-ons. This is the identical configuration on my Buzz TV X5, Mecool KM2 and Onn 4k Plus. The times that the Z11 links in Stremio and Syncler do not play is very frequent -- it's rare that any of the other 3 have similar issues. They all find numerous links -- that's not the problem.
    I have the Z11 and Buzz connected thru my A/V receiver to an LG OLED TV so I can switch back and forth between the two devices. I often find the same link will play fine on the Buzzz and not on the Formuler. I have tried both the built-in ExoPlayer and Just Player as an external player. Doesn't seem to make a difference. Also tried switching to Google Public DNS without curing the issue. Still not giving up. Using Nord VPN on fastest location on all boxes. Going to play around with different country server locations and also trying Surf Shark VPN to see if either change makes a difference. Will update if I get any breakthrough.
    Someone say Italy or Canada, Denmark worked with it.
    For the rest i don't know, just try my friend.
    Goodluck
    Since the update, trying to play a certain 4K movie from one of my portals just gives me a spinning wheel and seems to make the box unstable. Live tv doesn’t work and other apps, remote eg, don’t work. A reboot resolves this.
    The same movie on my Z11 pro max works fine and gives no errors.
    Mol3 have it sometimes that. Also on Z11.
    You can reboot but you can also in mytvonline3, menu, Content manager, data sync, contents data and then refresh do.
    Is faster.
    Goodday
    Over the time,since the update,i more often have sudden freezing of a live tv channel,normally tthis can be solved by switching to another channel,this however does not work lately.
    It esp.occurs when i switch channels via back button press in last viewed channels.
    Anyone else noticed this?
    No sorry, not at my 5 portals.
    Time? After 15 min, 1 hour? Or different?
    Btw: u use wifi right? Switch to utp cable. (Minimal a cat5e or cat6 cable) Just for test and turn off wifi and reboot.
    Thanks, my version won't run at all
    Correct, it's in the google playstore.
    But that (beep) Netflix didn't give a license to Formuler.
    Reason: to less boxes sold or so.
    Anyway, if you have netflix on tv use that please.
    Hd/4k and better sound.
    If you don't have netflix on tv.
    Then is the only way to download it from the market and use it with mouse and keyboard.
    But save money and buy a smarttv with netflix. Lg 2023 55qned866r 2023 is very good. Or something else.
    But if you have a lot money then a newer lg qned 100hz/120hz or if you have 1500 a 2000 euro then buy lg oled tv.
    Hope they also fixed the error I got with the last update that the box starts when I watch my satellite receiver.
    Has now happened again.
    The VPN menu appears and the box shows that it is turned off. (red).
    Then have to turn the box off.
    I hope it for too for you.
    But i don't know when the update will come and what the big changelog is.
    We can only wait...
    Goodday my friend.
    Is there any way of getting Netflix to run on a Formuler Z10 Pro Max?
    I have a valid subscription but although it used to run, it now refuses
    Is there a workaround? I'm not trying to do anything dodgy here.
    1 way only.
    Download it from formuler market app. (Green logo)
    But it's sd quality and you need mouse and keyboard to control it.
    If possible, use netflix on your tv for better image hd/4k and sound.
    Here is the video that I was watching!
    From 8k HDR world!
    ANIMAL KINGDOM 24K HDR – 4K Forest Wonders in 120FPS (Dolby Vision
    A quick search on YouTube should find it!
    Thanks for the video.
    Gonna watch it. Did you already search for dolby atmos 4k/8k or so on youtube? Great movies with the sound 😃
    I have just tv speakers that supports dts-hd and dolby atmos and passthrough dolby atmos thruehd etc.
    But im looking for cinema set. Maby the samsung hw-q930-f and 2 others. But all expensive. I'm looking for one that has 1 or 2 hdmi in ports for extra devices and with backspeakers. And it must dts-hd and truehd atmos supporting. But dts-hd is difficult to find. Yes jbl 1000 bar. But so expensive.
    Goodday.
    4k and 8k tv's are already on market.
    24k movies don't excist right? Tv should change it to 4k.
    But i love to see it. Will search for it.
    Btw my friend, also nice to search for test movies of dolby atmos 4k or so on youtube and or 4k dolby vision. Beautifull movies and sound. Search and see a couple of that movies.
    Goodday my friend
    Goodday my friend,
    How are you today?
    Is your box in settings menu really on standby or shutdown. Please check it.
    Right upper corner and then to right. You see other menu with energy modus. Is it on stand by, or shut down?
    Try to install latest software version if you did not already. Beta is final now so.
    Great choice the Z12 my friend! Yes okay, it need some updates. But one is a hughe update and it's coming soon!
    Like every new product like Windows, Linux, Cars, Tv boxes, TV's etc.
    All need updates.
    I wish you a good weekend and give the small team the time to finish the very big Z12 update.
    Let we hope they get it done before end January. It are a lot of fixes and testing takes many time.
    Goodday my friend
    Same here, since today suddenly the audio is gone. Rebooted the device, still no sound.
    Using the app to connect the BT3 and side buttons for volume. No audio..
    And connect the volume on the remote with correct tv. Did volume go up and down?
    Did you use volume button above on remote also? (not on the side)
    Lol, I will live with these minor problems. It has taken me 12 hours to get the box the way I like it. There is no way I am backtracking.
    Thank you for your reply, it is appreciated!
    Stubborn.
    Sam just want to help you.🤷🏻‍♂️
    Then go further with your box and don't ask help anymore.
    It's a forum for help? Why so stubborn.
    I resettet it also 2 times.
    So what.
    Backup of mytvonline3 restored via usb and that was the importants thing.
    Rest can you do later. It's almost weekend.
    For about 2 weeks now, I’ve been having a very strange experience trying to watch TV and movies on demand on my IPTV. What happens is if I restart the device majority of the time I can get an episode to load, if I want to switch shows or watch a second episode of the same show I get an error. If I restart it usually works again but it obviously is annoying. I originally thought it was on my IPTV providers end but I experimented with a free trial of a new provider and exact same thing and I now think it is a hardware issue. Anyone experience this before?
    Sometimes, once a month i have it. Mostly provider related!
    Fix: refresh sub.
    Z10? Mytvonline2, menu, refresh!
    if you posted in wrong thread and have a Z11 or Z12: mytvonline3, menu, Contentmanager, contentsources, sync data, refresh. Wait till youn see popup and click on OK. Can be some time.
    User is reporting error message being displayed when starting MOL3.
    Please check your internet connection (0)
    A network error has occurred
    Youtube and other apps on the box have internet connectivity and work. Box connected via ethernet (cable). I searched this forum and came across multiple reports of exactly this same error but none have a solution provided. Other users with same error report that resetting the box, re-installing MOL3, power cycling the box, router, change DNS (user does NOT use Cloudflare DNS), etc. did not solve the issue.
    What causes this error and how can it be solved?
    MCIF
    Provider is blocked by isp, cloudfare, quad9 and or by other dns provider and or vpn providers.
    You say a user report...
    ...so i think you are a reseller. If yes. Read the news and tv sites please better and test everyday your portal if it works or not.
    And read tv website news! Very important. Then you should known that Europe is blocking a lot of portals!
    Illegale IPTV in Europa moeilijker door nieuwe technieken
    De strijd tegen illegale IPTV wordt in meer Europese landen verder opgevoerd. Hierbij wordt gebruik gemaakt van nieuwe wetten en technieken.
    www.totaaltv.nl
    Acties tegen illegale IPTV tijdens Afrika Cup voetbal
    De komende weken wordt in Marokko het voetbaltoernooi Africa Cup of Nations gespeeld. Autoriteiten hebben acties tegen het illegaal kijken aangekondigd.
    www.totaaltv.nl
    Please translate links with google translate. Didn't work at my side.
    otherwise i did it for you ofcourse.
    Provider is blocked by isp, cloudfare and or by other dns.
    You say a user report... i think you are a reseller. If yes. Read the news and tv sites please (better).
    Then you should know that Europe is blocking a lot of portals.
    www.totaaltv.nl
    News text: ⬇️⬇️⬇️
    Europe becomes more difficult due to new technologies and legislation
    The fight against illegal IPTV is intensifying in more European countries. New laws and technologies are being used for this purpose.
    December 19, 2025
    France, not Denmark, will become the first European country to tighten the reins on illegal IPTV. This is initially based on an emergency law that has been passed, making it easier to block websites. Previously, France was similar to the current situation in the Netherlands. To block a website hosting illegal sports streams, for example, a court had to be authorized.
    Emergency law
    In France, this situation has changed thanks to an emergency law. This so-called 'sports law' makes it much easier for rights holders like Canal+, beIN Sports, and DAZN to take action against illegal streams. A court authorization to block sites only needs to be requested once. This authorization is then valid for the entire season of the sport in question.
    Siteblocker
    This is the first step in preventing the use of illegal streams. Technically, a new technology is expected to be implemented shortly that will automatically and independently block illegal IPTV services and streams posted on websites. The new technology will initially be used primarily for sporting events. This new approach will also involve the use of VPN and DNS blocks.
    Detour
    Whether the French approach will actually significantly impact illegal IPTV remains to be seen. Users with expertise in the field can likely easily bypass blocks. However, so-called "plug and play" viewers will face significant challenges in displaying the illegal stream on their screens. Whether the technology being deployed in France in 2026 will also be implemented in the Netherlands at a later date remains to be seen. First, the legislature, like France, will need to make the necessary legislative changes.
    www.totaaltv.nl
    Illegal IPTV during Africa Cup of Nations football: outages for Dutch users also possible
    The Africa Cup of Nations football tournament will be played in Morocco in the coming weeks. Authorities in that country have announced actions against illegal viewing.
    December 20, 2025
    The Moroccan government has engaged foreign experts to launch a large-scale, intensive campaign against illegal viewing during the Africa Cup of Nations. According to the authorities, these previously announced actions are necessary because illegal viewing of sporting events, in particular, is commonplace in many households in Morocco.
    Collaboration
    The Moroccan government will collaborate with the European Union and various partners in the sports entertainment and audiovisual sectors in the announced actions. The latest technologies will be used to immediately block illegal streams using so-called "fingerprint technology." Several European countries, including France and Denmark, also intend to use the same technology from mid-2026 to prevent illegal viewing. A tougher approach to illegal IPTV is also being prepared in the Southern European countries of Italy and Spain. For example, a law was recently passed in Italy that will soon make it possible to track users and impose hefty fines. This partially overrides the privacy of residents of that country.
    Also possible
    The Moroccan government's actions during the Africa Cup of Nations could also lead to sudden black screens on one or more channels for Dutch users of illegal IPTV subscriptions. It is known that some of the servers hosting illegal streams from channels and streaming services are located in Morocco.
    Google Translate
    Hi
    so apologies if this subject has been covered in earlier posts, did a quick search and nothing that answers my question
    If i choose to sell the neighbour or anyone a z11 pro, is there anyway of hiding the portal url in the mytvonline3 so they cannot see it?
    Id you filled in. It become dots the text like username, password and url.
    you can only see it when te go to Contentmanager and then contentsources and then click on the eye!
    I highly advice to do not hide the url!!
    By custom code.
    Why?
    Because isp providers seen when you are streaming and in europe they are haunting on portal url's to set on the blocklist at all dns providers.
    Cloudfare, quad9, your isp etc.
    If url is blocked, they can't change it by self. Also sometimes the formuler servers are blocked. Have one seen here in my country at a small isp provivder. So they can't also update there box and nor update the configuration file.
    Stop the costum firmware💪🏻💪🏻
    Its obvious that something is incompatible and not recognised well, but the question is the benefit of such device on Z12?
    Incompatible it should be then ofcourse yes.
    1 ordered two usb3 to 2.5gig ethernet, but got 3 delivered.
    Ome for my nas server to the 2.5gig switch.
    And one for pc.
    The one that was left over i tried on my Z12. Just for fun. And then i knew that there maximal 1000mbit must stand at ethernet. But it shows 100Mbits.😂
    So not 100% compatible, but with speedtest in get above 100Mbit.
    Tomorrow i disconnect it en plug in cat7 cable direct and done.
    thanks for your answer. You can close thread please. I can't.
    Sorry Lucky but i don`t understand what explain you await from us about device like usb3 to 2.5gig ethernet adapter connected on Z12?
    What do you expect from this device with Z12? You will not get the 2.5 g that`s for sure.
    I know my friend sam.
    I got now 2.5gig at home. Cat7 cables and switches.
    I understand i won't get more then 1000Mbps.
    Only thing what i want to let you see are 4 things:
    1: Vpn key logo on homescreen is gone, since connected to usb3 to 2.5gig ethernet adapter. (Photo 2)
    2: Link speed on 2nd photo says 100Mbps??? Should be 1000Mbps (Photo 3)
    3: Nordvpn is on yes, so key protection logo should appear on homescreen. But it's not. It's only availeble in mytvonline3.
    4: speedtest says with nordvpn on over 200Mbit. Without nordvpn 1400gig one time. (Photo 5)
    So the 100mbps on photo 2 isn't right.
    Having now read about this, it must be an XCapi Portal I am using. Either that or I have completely misunderstood this! The playlists of live, vod and series all load and all function fine. I just cannot edit the groups of the live channels. I presume that there is a limitation on file size.
    I only added the equivalent m3u file size to put the amount of channels lists in some perspective. I am much more familiar with enigma2 devices.
    If this is your url as example:
    http://line.watchtv.com/php?username=abcdef&password=123456&type=m3u&output=mpegts
    Then fill in at portal name: your provider name.
    At url: line.watchtv.com
    Username: abcdef
    Password: 123456
    Connect.
    Goodday my friends,
    I have updated my house with CAT 7 ethernet cables and a 2.5gig switch.
    I connected the "usb3 to 2.5gig ethernet adapter" to my usb3 port on my Z12 when box was on.
    And ofcourse a cat7 in the ethernet port of the adapter DIRECTLY in the 2.5gig switch.
    I use Nordvpn.
    After restart box i saw on the homescreen:
    no key from vpn security.
    At network settings at link speed: 100Mbps (yes 100), not 2500
    Nordvpn is ofcourse connected!
    IP checked and was good.
    In MyTVOnline3 you see the key.
    (Is good, so it's protected.)
    And when i did speedtest i became above the 100Mbps. (Yes, i know i don't get full speed with vpn😉. But it was described at ethernet settings as 100Mbps) and when i put cable direct from switch to ethernetport Z12 i got direct 1000Mbps.
    But i just wanna show you what i see.
    See pictures my friends.
    SAM  F_Peter
    How about that😂😂😂
    Lucky13 This option is not available in GTV.
    😂😂😂 you are right.
    Maby make photo of your favorites!
    Remove mytvonline2.
    Restart box!
    Reinstall mytvonline2.
    Fill in tv credentials.
    Change every channel till you see "audio codec update" or so.
    Do the update!
    It can be doing only once.
    Hopefully it helps.
    You Didn't change your setup with sound(bar) or settings?
    Otherwise last option factory reset!
    Goodday my friend.
