I use torguard vpn app. It says that always on is not supported. I would like to have support for that.
Torguard
Hello my friend,
Why not use nordvpn and or Surfshark vpn?
Goodday
I went thru a lot of vpns. Surfshark lost too many packets. Can only run in udp. It was horrible. Had an argument with PIA and left them after proving them wrong. I don't trust nord and and lot of other vpns. Went with torguard. I had a problem with ipv6 was not encrypting with them. I showed them. The next app update allowed you to turn off ipv6. There support is excellent. Quick to answer problems. Had them for years, couldn't be happier. I haven't checked if any vpn can encript ipv6 yet. You do know a lot of vpns can't do that.
Does your vpn support always on in your formuler box?
Yes nordvpn connect automatic at startup and switch to faster server if needed.
Fully automatic.
Auto connect disconnects when the box sleeps then reconnect when it wakes up. Always on stays on and never let the box disconnect. Also while in that mode if the vpn disconnects it doesn't let anything in or out until you reconnect the vpn. I have checked, works well.
Yes nordvpn connect automatic at startup and switch to faster server if needen.
Funny, I had a server that got me 450 mbps. Had it for the longest time thanks to always on. Till the power went out.
Vpn secures your connection and slow it down yes. Do all VPNs, But that's due encryption. Nordvpn is the number 1 vpn.
I think you should go to cybernews dot Com.
You are right, like I said. Nordvpn the number 1
You went there and did a nord ad. Long story to fix that. https://cybernews.com/security/fake-…-breach-claims/
Just because you can doesn't mean you should. Don't think this is the place to discuss this.
Way cool, they started a thread for torguard. Don't use playstores app , sideload for full settings. Use torguard dns to stop ads. Thanks mods.
Nordvpn stays in standby modus.
When you put on box and go to nordvpn app you see above "time connected severals hours"
All postings moved into own thread, request thread is only for requests and no discussions! Please follow the rules, Lucky you too.
It's not just about what the vpn company does. Trust is a big factor when picking one.
https://www.pcmag.com/news/nordvpn-actually-we-do-comply-with-law-enforcement-data-requests
Why TorGuard VPN is One of the Most Trustworthy VPNs on the MarketWhen it comes to VPNs, trust is everything. Many providers make bold claims about privacy and security, but few can truly back them up with…medium.comWorks well in tcp for my computer. Udp, not a problem for smooth streaming. Formuler z11 handles the encryption well. Have the z11 for over a year, couldn't be more happier with it.
