What can be done to overcome this limitation? Can the Google updates be disabled?
If it can't be overcome, Formuler should stop selling systems that have inadequate resources to accommodate the aggressive bloatware from Android/Google.
Im a big Formuler fan since the first boxes i had since 2014 or so. Formuler Z, Prime, Z+ and the Z neo.
But this box (Z10 neo) is one with too less space. Had to overcome to my friend to factory reset and then update the box.
Better safe money and go for mininal a Formuler GTV.
Or the expensiver ander better Z11 pro max bt1 or the best like the Z12.
Fix: delete cache and update Google play store,youtube etc. And if possible and installed delete also expressvpn.
Or direct after factory reset do software update.
Then install audio optimizer, run it and box will restart. Then you can delete audio optimizer.
And contact your iptv provider remove all your countries except the ones you watch!
if provider removed the countries you don't watch, remove cache memory from mytvonline2 and restart box.
That safes also a lot of space!!
