Fantastic thanks so much for your fast response
Posts by rbargante
Hi everyone what the easiest way to
Factory reset my Formuler Zx thanks in advance
I already did
They told me to change DNS... But no improvement until now.
Please let me know if you fixed your issue. I'm having a few issues too. Thanks
Anyone had experience with Surfshark? Any issues with Z8?
what is your issues?
What is your current version of NordVPN?
When was the last time you restarted your internet (provider) (cable)modem/router?
hi. normaly i restart my internet router box etc once a month. i just found a vpn that works fine with my z8 . thank a lot for your help
I saw this behaviour with the version of nord vpn before last version came out, has nothing to do with Z8 update, because even nord vpn on pc blocked the internet.
ye you rigth even in pc nordvpn blocked internet. so what vpns do you guys advise to use with formuler z8? thanks a lot ( what about surfshark ? ) really apreciate you help. thanks in advance
Yes Internet working 💯 without vpn. I ask them thanks
You can try changing NordVPN settings like switching protocol from UDP to TCP. And try switching to a different country in the NordVPN app.
And last but not least: NordVPN has a webchat for support. I have good experience with that. They usually have some good suggestions about what you can try to resolve issues.
hi. is nothing to do with nord. ive been using nord long time now with formuler z8 no issues till the new z8 firmware updade. even going back to the old version of nord on z8 not heps anymore. its will work for a few moments but then it bloks all the iternet. after connecting with nord i do o dsl test ad comes to 0.
I assume you are referring to the Z8 firmware update when you write "last update"?
If yes, did you know there is a NordVPN update also available in the Market app? Can you try that first?
Hi thanks for help. Yes refeing to z8 firmware. And I updated the nord for the newer version. Took to long to login and after logging in couldn't watch live TV. I havd to desinstal nordvpn. Restart box and install the older version. And it works again. So in my side the new nord vpn version doesn't work well. Thanks again 🙏
Sorry to jump on your post. But I have the same problem after I did the last update nord vpn takes long time to connect. But when connects it takes all the Internet speed so I can't connect to Internet when nord is on. Please can someone help? Thanks in advance
Hi how to use
Picture in picture in z8? Thanks
Like 175n already wrote, see quote. The hotel page shows the policy page.
Thanks very much for your help I will try out a couple more times aand see how it goes thanks very much
In most cases when you get from hotel stuff your login data, you just need to connect with hotel wifi , open webbrowser and login start page from hotel should appear. After enter login data the box is online.
Thanks for your fast response. My situation is a bit different I just need to accept the policy page to get connected. To conect I need to accept the policy page first so how can I connect and open Firefox etc?
Hi sorry to jump into your post.
I have same issue. I have Firefox tryed your method and nothing upend can someone help please thank you
I know these have been mentioned before, but there are 2 features that would be really really awesome:
1. Create own favorites groups, and ability to reorder those groups (just reordering of my own groups, reordering of provider groups is not needed in my opinion).
2. Inside my own favorites group(s) add the ability to reorder the channels.
This should be important 😊👍🙏
Thanks for your response.
Will this work on zx? Thanks
I'm in UK
https://www.amazon.co.uk/dp/B077B7DW2X/…1_t1_B079LYDWCC
The best wifi dongle in my tests was this one -> S and Z series compatibility test and devices.
Hi please can someone tell me what wifi donglle are compatible with zx? Thanks very much 👍
Mybe yes. It worked for me with this speciific service. Thanks again 🙏
Hi. Thanks very much for your help.
I deleted the portal. After I forced stop mytv2 and cleaned the cache.
Added the portal
And it worked fine
Again thanks a lot for trying to help 🙏
Are you able to provide a trial to me so I can test if it works on my side?
ye sure. just sent you a 2 days trial. thanks a lot for help... let me know somting as soon you have anithing
Hi not sure if someone is able to help.
I have z8 is working perfect with
Most of the services.
But I have a specific service that not working with mytv2.
The channels are black no sound no image.
I installed iptv smarterrs on z8 and same service is working.
So it works with iptv smarterrs on z8 but not working on mytv2
Z8
Current firmware :v1. 4.14
Current iptv version :v7. 1.1
Systema formuler z8
Thanks in advance
I got the Zx for over a year now and it works great never no problem
Thank you. Just bought 1
Same principle with wifi. Any questions, feel free 👍
Hi codeit.
I have a firestik and works fine on my WiFi connection.
Also my pc is connected on same WiFi when Image freezing on z8 and in pc is still working fine.
Z8 image freezing and WiFi icon on my online tv is blank like it lost connection and couldn't reconect.
I have a friend with same problem.
I'm using it wired and works great but my friend don't want to spend more money on powerline after spending 130£ in a box 🤔
I tryed to increase buffering to 10 but it not help.
We need something easy to fix instead messing with routers.
I had other android boxes with no WiFi connection troubles at all.
I'm advicing this box to all family and friends and they don't want to mess with router settings too.
Any advice will be much appreciated thank for your help
Hi everyone.
Me and my friend having same problem.
Image freezes time to time.
Z8 looses wifi connection.
Need to change channel to restart WiFi. And sometimes I have to turn WIF off and on again to restart network.
Even if was a wifi drop it should connect back straight away?
Works good wired.
I think it should be a easy fix around.
Not everyone wants to mess around with router setting etc.
I might doing something wrong
Maybe need to set buffering?
Any advice will be fantastic. Thanks again
Fantastic. Thanks so much for your help 👍
Hi I have z8 and I'm very happy with it.
I have a friend who wants to buy a cheaper box.
Will this box zx be good just for live tv?
Any advice from people who ready have it?
Thank you in advance
formuler z8 remote control functions:
where to find a manual, picture or something similar? Thanks
hi everyone. it been on all night on all day and no drops at all. looks like the update fixed the problem at least till now.... thanks everyone for all the time spent with my problem really appreciate.
Did you test it??
Or are you testing now😀
im running a ( pig to keep connection alive on pc.
https://www.techwalla.com/articles/how-t…onnection-alive
running 1 service iptv on pc and 1 in z8 left over night on and no drops.
will be running during the day and see if drops occur.
yesterday i had 1 or 2 drops during the day. one of the drops not accursed on pc just on z8 so i think the problem is not 100% fixed from my side.
image in z8 freezes, takes to long to reconnect. or no reconnects at all and i have to reconnect manually again.
i tried a app on z8 to pig to connection alive (pigip app ) but z8 wont let this app running in the back.
is Anny way to let apps running in the back on z8?
when z8 loses WiFi connection it should be connecting back fast as possible ?
thanks you for everyone trying to help me
Did you test it??
hi . im testing now. ive been busy. will leave it on over night and all day tomorrow and see. if any drops occur i will ask for help .
Home > Quick Settings Row > Reset > Factory Reset.
ALL DATA WILL BE DESTROYED and the device will be reset to factory state.
thanks a lot
Great news my friend.
Yes after an update its better to do a factory reset if you want.
Let us know please
Please can you tell me how to do a factory reset? Thanks
hi everyone i just isntalled the new update no drops till now. will keep testing . another question just read in a group we need to do a factory reset after firmware update? thanks everyone.
If you post what your ip address of the WiFi adapter is and the ip address of the dns I'll explain for you what to do to manually assign a static IP address to see if that works for you. Although I have just read the official update is available tomorrow, maybe that will solve your issues 👍
Hi. You very kind. Us good news the new update is coming 😊.
If it doesn't fix my problem I can give you access to my router and you can try to help me. What do you think? Thanks a million 😇 🙏
If you change your network configuration on your box in the network settings and give it a static IP address then dhcp lease time won't play a factor into your network connection. Personally I think its more of a compatibility issue with various routers /brands/chips as I haven't ever had any WiFi issues at all, I stayed on the very first build up until the latest beta, then I upgraded to the beta version, I still don't have any WiFi issues so from what I read from various people's issues it seems like compatibility with various routers etc. There's a lot of misconception of people's understanding here about wifi/network/dhcp/router/ configuration, I know people are only helping which is great an cannot fault the community but I do think it would be ideal if formular had not just various catigorise for various issues but also had catigorise with factual information across the board i.e network topology, ip addressing etc so that people have a better understanding of how networking works and how it can be configured in various settings / scenarios etc... Just my thoughts on this as it would help the less knowledgeable people that are keen to learn and dig in setting up their devices.
hi thanks very much for your comment. on my pc i have wifi connection no drops . on z8 i have drops and the big issue it wont connect back. just freeze image and i have manualy conect back wifi.
Display More
I see no problems so far.
I thougt your leasetime ware a couple of seconds but its great.
Maby you can change the limit to 175 or 200.
Maby you can try to give the macadress of your formuler a static adress in your router.
00 1a 79... Can you give 192.168.1.120
Maby you can try to find the wifi mac . You can find it if your box is connected by wifi on your router.
Mine wifi mac begins with d8-47...
Give it 192.168.1.121 as static adress on your router.
So 00 1a 79... --> 192.168.1.120
(Wifi mac) --> 192.168.1.121
Maby you can change your dns to 1.1.1.1 if you didn't it already.
Restart router and formuler. And connect to wifi again on your formuler.
Give it a try my friend. Maby it helps.
thanks for trying to help but im not sure if i will be able to do that.
i will try anyway, thanks a lot
