Posts by Den123
Hi al when I set to record it don’t record all program. Records approx 10 mins then stops have formatted h/d
What did you format it to fat32
Rufus formatting can anyone please tell me what the settings should be for me to format h/d. Thanks guys
Seems to be going not good with update for GTV
Try express vpn. Trial. I have had no probs up to yet If I recommend a friend. We both get. Extra. 30days each on our account thanks
Where do I get them all from mate
What make is it mate
Thanks mevi. Where can I buy it from mate
Hi all best dual band antenna fir the z8 any suggestions please
It happened on mine today after update. This is what I found out. I switched on box. It was black screen. I turned off. My vpn. And it came on then put my vpn on again. All ok. Then switched box off. Then on. Black screen. Turned off vpn again all came on. So could it be a provider not allowing vpn.
Cheap Stella by the case anyone know the cheapest please
Coming very very soon.
Have 1 on me mate
say no more mate lol
Sams chilling waiting to sit outside in the rain with a beer lock down near the end lol
No get a GTV
This happened on mine also
Try putting on your router the vpn
Is your box synced with the av and tv
Nice one Sam mevi. Think this should be closed
What about other connected devices you want to sync
I think a lot of the problems are provider. It’s so easy to say it’s your formuler box. I would say 99% are provider.
Reboot router
What was wrong with the GTV
hi guys. Is It possible to transfer vod to a usb stick
When are the updates for the GTV Sam please
Thank you MeV// is there any special setting for it
Hi guys what’s the best VOD PLAYER to use
Thanks Sam will do
What dose this mean. An error occurred. InvalidresponcecodeException.
Hi guys box being good now started to get black screen. Was on a channel. Changed channel went black and stayed black any ideas guys
Stella Stella
Thank you mate will send you a beer. Carling. Lol lol
Dose not say mate
Can the same plug be used on the GTV. and Z8
I will buy it GTV
