Hi al when I set to record it don’t record all program. Records approx 10 mins then stops have formatted h/d
Recording
- MYTVOnline2
- GTV
Den123 -
April 1, 2021 at 11:03 AM -
Hi, I sometimes encounter a problem when I schedule a recording via the EPG, I press the red button to record to access to the schedule, I indicate the day and time of recording. The day after, when I want to watch the recording, it erases other recordings and sometimes it doesn't record the program. Do you see anything that looks like your problem?
Few things you might want to check first:
1. Your external drive formatted exFAT or NTFS
2. Enough storage in your drive
3. Set recording duration manually
4. Stable network
Hi, my device is fine, it is connected to a HDD 150G enough space. Formatted NTSF. Manual recording is working fine but when I schedule a program via EPG, it will record for the time I set but the new recorded program will erase the one previously recorded. thanks
I installed the MYTVOnline2: 9.2.9 BETA one month ago. Wondering if it could it be related?
