Display MoreHi folks,
I'm new around here and I hope this helps a few people and welcome any suggestions or other tips.
I do not personally watch 4k material through the Z8. My sources are both European and North American IPTV never exceeding 1920x1080i/60fps.
I change the Z8 between 1080p/50Hz and 1080p/60Hz and I prefer to let my TV convert to 4k at the display itself as it displays the best PQ for SD/HD IPTV material.
The output of the Z8 was metered with a calibrated i1 Display Pro whilst running slides and test material.
TV: LG OLED B7 Professionally calibrated to Dark Room 40ftL 2.4 Gamma
Formuler Z8 Settings
Settings - Advanced Options
YCbCr444 8Bit **Safe output for material viewed**
TV HDR Mode: SDR
PQSetting
Display Mode: User Defined
Brightness: 49 **At default 50 black is not completely black**
Contrast: 50 (Default)
Hue: 50 (Default)
Saturation: 49 **Saturation 50 is slightly above what saturation should be. 49 is the closest available and helps offset color/skintone anomalies**
Imprex Engine
Display Mode: Full Screen
Intelligent Color: Optimal **Best available skin tone and overall color setting**
Dynamic Contrast: Off
Sharpness: 20 **Personal choice to help offset sharp edges of compression blocks inherent in IPTV**
Noise Reduction: Off
MPEG Noise Reduction: Off
Motion Compensation: Off
HDR Saturation: 50 (Default) **I do not use the Z8 in any HDR mode**
Posts by Bou
Display More
Hi folks,
TV HDR Mode: SDR
PQSetting
Hue: 50 (Default)
Imprex Engine
Toutes les boîtes ne prennent pas en charge le HDR.
ha zut ok merci
Hello everyone,
good news kodi 19 can be downloaded here. In addition for the first time on formulating z8 you will even be able to read your bluray menu in iso format. on the other hand still no progress on the possibility of having an atmos sound on kodi on formulating damage. Especially that on other applications on the formulate Z8 it is possible.
J'ai mis à jour via le Play Store vers la version 19, j'ai eu l'erreur: "Le logiciel a provoqué la connexion interrompue", vous pouvez résoudre ce problème en:
Paramètres -> Services -> SMBclient -> Minimum = V1, Maximum = V3
Sachez que certains des les ad-don déjà installés peuvent cesser de fonctionner en raison de l'incompatibilité avec la nouvelle version de Python 3 dans Kodi 19
Donc, si vous avez beaucoup d'add-ons installés, vous feriez mieux d'attendre avec la mise à niveau vers la version 19 jusqu'à ce que les addons soient rendus compatibles avec Kodi 19 ( Python 3)ok thanks we will wait.
The new Kodi 19 matrix is out. Anyone know how it is possible to have it over formulate Z8? please
thank you
I have a problem with DTS and 7.1
With the mytvonline application no problem to read DTS, DTX, True HD etc ...
On the other hand I have better quality films in UHD on plex, on the other hand apart from DD 5.1, impossible to read another format.
Can you help me please.
Thank you 2
Good news, the internet is back. Thanks SAM
Despite the installation of the second beta (beta v1.4.56) the exclamation mark is still present. I do not have internet, impossible to be connected to mytv 2 (code 7). By cons no problem for the use of youtube.
La
Contact me trough Conversation (PM) ill give you entry for second beta and stop to post in other language..
ok Thanks
La
Après avoir installé à la fois la première version bêta (v1.4.55) + la deuxième version bêta (v1.4.56) + l'avoir exécutée pendant plus de 24 heures, je continue de rencontrer le "!" assez fréquemment lors de l'utilisation du Wi-Fi (utiliser le réseau 5G) Je suis sur le canal 153 + mon nom de réseau 5G diffère de mon 2.4G .. Je n'ai pas la possibilité de tester Ethernet. Peu importe si je suis dans MOTV, TiviMate, Plex ou l'application Youtube. Quelle que soit l'application dans laquelle je suis, elle s'arrêtera + prendra de 10 secondes à plusieurs minutes ou parfois un redémarrage afin de rétablir la connexion. J'ai essayé avec les deux l'IPv6 désactivé + activé. Essayé avec VPN off + on ne fait pas de différence non plus. J'ai une autre boîte Z8 dans la chambre qui exécute cette dernière mise à jour officielle (v1.4.53) sur le Wi-Fi 5G + à peine plus de problème sur celle-ci
beta (v1.4.56) ?
La
But how you get then the error 7? Please explain in detail, when it happens and when not?
My box says it's connected in the configurations, but it shows an exclamation point (!).
