Hi folks,
I'm new around here and I hope this helps a few people and welcome any suggestions or other tips.
I do not personally watch 4k material through the Z8. My sources are both European and North American IPTV never exceeding 1920x1080i/60fps.
I change the Z8 between 1080p/50Hz and 1080p/60Hz and I prefer to let my TV convert to 4k at the display itself as it displays the best PQ for SD/HD IPTV material.
The output of the Z8 was metered with a calibrated i1 Display Pro whilst running slides and test material.
TV: LG OLED B7 Professionally calibrated to Dark Room 40ftL 2.4 Gamma
Formuler Z8 Settings
Settings - Advanced Options
YCbCr444 8Bit **Safe output for material viewed**
TV HDR Mode: SDR
PQSetting
Display Mode: User Defined
Brightness: 49 **At default 50 black is not completely black**
Contrast: 50 (Default)
Hue: 50 (Default)
Saturation: 49 **Saturation 50 is slightly above what saturation should be. 49 is the closest available and helps offset color/skintone anomalies**
Imprex Engine
Display Mode: Full Screen
Intelligent Color: Optimal **Best available skin tone and overall color setting**
Dynamic Contrast: Off
Sharpness: 20 **Personal choice to help offset sharp edges of compression blocks inherent in IPTV**
Noise Reduction: Off
MPEG Noise Reduction: Off
Motion Compensation: Off
HDR Saturation: 50 (Default) **I do not use the Z8 in any HDR mode**
