The new Kodi 19 matrix is out. Anyone know how it is possible to have it over formulate Z8? please
thank you
thank you
Update from google store?
https://www.apkmirror.com/apk/xbmc-found…d-apk-download/
For a STB , 32b will be chosen.
I have updated through the Play Store to version 19, i had the error: "Software caused connection aborted", you can fix this by:
Settings -> Services -> SMBclient -> Minimum = V1, Maximum = V3
Be aware that some of the already installed ad-don's can stop working because of the incompatibility with the new Python 3 version in Kodi 19
So if you have lots of add-ons installed you better wait with upgrading to version 19 until the addons are made compatible with Kodi 19 (Python 3)
J'ai mis à jour via le Play Store vers la version 19, j'ai eu l'erreur: "Le logiciel a provoqué la connexion interrompue", vous pouvez résoudre ce problème en:
Paramètres -> Services -> SMBclient -> Minimum = V1, Maximum = V3
Sachez que certains des les ad-don déjà installés peuvent cesser de fonctionner en raison de l'incompatibilité avec la nouvelle version de Python 3 dans Kodi 19
Donc, si vous avez beaucoup d'add-ons installés, vous feriez mieux d'attendre avec la mise à niveau vers la version 19 jusqu'à ce que les addons soient rendus compatibles avec Kodi 19 ( Python 3)
ok thanks we will wait.
Hello everyone,
good news kodi 19 can be downloaded here. In addition for the first time on formulating z8 you will even be able to read your bluray menu in iso format. on the other hand still no progress on the possibility of having an atmos sound on kodi on formulating damage. Especially that on other applications on the formulate Z8 it is possible.
