  • Hi everyone.
    I'm struggling to decide between the z11 mini and the pro max... I'll be using it for streaming and very occasional recording (only apps I'll use will be mytvonline and YouTube) and I will be connecting it to a Valerion visionmaster pro2 probably through a AV receiver...I don't think I need the AI upscaling as I think it's best to let the projector do that. I don't think I really understand QMS bit i watch a lot of sport do anything that minimises judder is good for me. Are there any other advantages of I've over the other? The form factor doesn't bother me either way. Any advice appreciated.
  • It’s the z mini not z11 mini. Minor distinction in that the z mini uses android 12 not 11 like the other z11 boxes.
    Out of the two, I’d go z11 pro max.
    The z mini is great, especially for the price, but the extra ram, storage and ports make the z11 just that bit better to use.
  • Thanks. I won't be able to run an ethernet cable to it so that bit doesn't bother me, if RAM would make a difference and the updated features of the mini help anything. But for £50 extra, if it's better I'll go for the max then.
