Remote compatability
  • Hi, I used to have a firetv and some of the apps I had on it are not available on the formuler market place, I can however get them on google play but it installs the tablet version of apps. Is there a way to have it install the version of the APK that is remote compatible.
    For example on the firetv I used to use UKTV play which is remote operated but the same app installed on formuler is the tablet version
    Thanks in advance for any advice
  • What i did with a couple apps was download then on pc and then transfere the APKs to flash drive and load flash drive in box. I also downloaded em to my phone and transfered them.
    Closed the thread.
