Problem with parental code for adult section (portal)
  • Hi Everyone,
    I just got a z8 and I noticed that in mol2, there is a bug with the parental control code function in the adult section.
    Once you go into the adult section, and you select a channel, the parental code window pops up, but if instead of inputing the code, you hit back and select another channel , it actually overrides the code, and plays the channel wide open, and even all the other channels in the section.
    I had a z7+ and I don't recall having that issue. It could be risky if kids play with the remote... I know there is the individual channel lock option but it would be annoying to input the code every time you change the channel. I hope this gets fixed soon.
    I tried 2 different providers and the problem is replicated. I have another box (original mac-based one, not to say the name), and the parental control works fine for both providers.
    Also, on the Z8, when you select the adult section, it actually displays the channel list before inputting the parental code.
    It would also be safer/nicer not to show the channel list before inputting the code.
    Thank you.
