MTVO2 and DIBSYS / TBS HDMI Encoder HTTP Streams
  • I got a Problem with you HDMI Encoder and the App myOnlineTV2 which is installed on a formuler Z8 5G IPTV Box. All Streams from the Encoder are lagging, all HVENC Streams not. So Problem is the Output from the HDMI Encoder i guess...do you have any solution?
    Yesterday i read about the AFR Settings in the Beta, but did not test it yet.
    Here is short Discription how it goes down:
    Local Receiver --> DIBSYS HDMI Encoder --> HTTP Stream --> IPTV Panel --> Client
    It doesn´t matter which Panel...i have a Panel most of u do not know it exist....but what i can say is, that i have the same Problem even with XC or other popular Panels.
    And only with Streams which are comming from HDMI Encoders. All other Streams like HVENC working fine like i said. And yes it´s connected via Stalker :smiling_face:
