RTSP Streams
    • Model: Z8
    • Retail Box or Provider Box: Retail Box
    • Firmware version: 1.4.62
    • MYTVOnline 2 version:
    • Connection with provider: NA
    • Box connected with: WiFi
    • Did you factory reset your device? and when?: No
    • rtsp://user:[email protected]/live/ch00_0
    • rtsp://user:[email protected]/user=xxx_password=xxx_channel=1_stream=0.sdp
    I want to connect two security cams within a playlist like this.
    #EXTM3U
    #EXTINF:1,CamDog
    #EXTINF:2,HouseFront
    My aim is to be able to view one or the other as Pic in Pic but the playlist is not compatible with MYTV2. It is compatible with VLC Player and I am using the popup player to overlay on the screen as a work around.
    Can anyone tell me if my issue is with the cameras, playlist or MYTV2?
    The workaround will probably be good news to many users that have had the same issue trying to connect an RTSP stream.
    :thumbs_up:Thanks, MontyG
    You gota know when to hold em:thumbs_up: RIP Kenny.
