hi
when i start netflix it ask for update but it cant update,
it says not compatibe with ur device
plz guide
regards
hi
plz guide
regards
See if there’s is a update on the market place
HELLO
It was update i rejected it , now no update 😢
Then download kodi install the Netflix’s addon
good idea thanx😃
hello,
can some1 guide how to install netflix in kodi on z8,
i dont find netflix addon
regards
Hi, i install, and update the Netflix, and Disney+ use the Apkpure https://apkpure.com/apkpure-app.html
Thank you.
Before when I installed netflix I also had this error, then I installed netflix techbigs and fixed this problem!
