Hey I’ve a problem with the Box.
When I go imo VOD it shows “Failed to load the Load”
After going out then again into VOD then movies appear but when I scroll down after like 30 movies the message appears again”Failed to load the VOD”!
Contacted my provider and he said that from their side all is good.
Can it be that the Box need an proper update for
Loading my VOD normally?
