HDMI CEC LGTV Magic Remote Stops working after a while
  • Hi!
    I got a LGUH750V with a magic remote.
    I have plugged in the Z8 Pro directly to my TVs HDMI
    I have enabled HDMI CEC and simple link on the TV and HDMI CEC on the Z8 Pro and it is WORKING! So far so good!
    But after a while it stops working and very randomly, it does not matter what application I use, MyTv, Kodi, Emby .. it just stops working. But the Z8 Pro work if I use the default remote.
    I then shut down the TV and restart it, still nothing, BUT when I reboot the Z8 Pro it starts working again. So the problem seems to be with the HDMI CEC on the Z8 Pro.
    What might cause this, have anyone experienced the same problem ?
  • I just got z8 pro other week, with BT remote, I can switch between Z8 and tv remote function,
    but i cant get it to access HDMO source automatically, ive gotta press and hold change to TV source and manually selevt source 4,
    each time,
    does the way you have it, auto select source using Z8 remote?
