issue with formuler z 10
  • Hi
    I have noticed when say you got to stream a movie and you slect that you want to use Mxplayer Pro there will be drop down box to select use it one time or use it always to play movie every time I select to always use it it won't remember this setting. You always have to select use once then next time you want to play movie again using the mxplayer have to select use once the always use doesn't seem to work. I have had this in a couple of different apps. Not sure if this is an issue that needs to be fixed in an update.
    Also in the mytvonline 2 app when in the vod section is there anyway in a future update that you could adjust the size of the poster for movie be easier to read them and the info.
    Also what about the color of the epg guide in the live tv section anyway they could add it so you can change the color of the guide?
