Channel EPG and Group EPG are showing different times both in Normal as well as in UTC mode
  • Hi,
    I reported this error earlier, but it still hasn't been solved.
    I have the latest version of Mytvonline 2 (as of 27-06-2022).
    The Channel EPG is showing the correct times, but in the group EPG there is a difference of 2 hours. This difference occurs both in the Normal as well as in the UTC mode.
    By changing the offset I can either get the group EPG times correct or the channel EPG times, but never both.
    This issue is very annoying.
    Please help.
    Kind regards,
    Rohin Mehra
  • Try the steps below:
    1. Android settings > Date & time > Revert the time settings on your device back to "Use network-provided time." Do NOT manually adjust the time.
    2. Android settings > Date & time > Choose the correct time zone and make sure the system displays the correct time.
    3. Mytvonline2 > Main Menu > Connections > Click on your portal > select Edit > Change "EPG Mode" to UTC. Scroll to the bottom and click "Update"
    Check the channel guide information to see if it lines up correctly.
  • Comments
    Refs.: HW : Z10Pro MAX / SW : mol2
    I was in the same situation, async between channels and epg list; 2 hours deviation.
    Following the above 1 – 3 pgfs which are correct but still no sync.
    So I make pgf 4:
    Set EPG OFFSET +2 as deviation was 2 hours
    Exit/restart
    In "Z10" Main: Settings > Device Settings > Date & Time > Set Time Zone:
    Check/Set CEST according to your current location. Note that "summer time" is relative to today's date and GMT. My location : GMT + 2.
    Restart and load mol2.
    By doing this, the epg list is synchronized with the program broadcast. What will happen going back to normal time, wait and see.
