Hi guys
Has any of you have the problem I have? I have formula Z8 box and a Z10 Pro Max box. When I in mytvonline2, play a movie from a link (vobsub) on the Z8, I have no problems, the subtitles appear. But when I do the same om the Z10 with the same movie, link and same player (External VOD Player Default), the subtitles doesn’t appear. There’s also some radio live links that works fine on the Z8, but doesn’t work on the Z10. I use the exact same preferences on both boxes, how come the newer box (Z10) isn’t “as good” as the Z8, am I missing something. Is the problem regarding the External VOD player (codecs etc.), is it possible to install the exact same version (installed on Z8) of the External VOD player on the Z10? Is it possible to fix this issue with the next software update. Anyone of you that have solved this problem??
Regards
Offenbach
