No recording programming posibble
  • Hello i can not plan a recording later on the day or on a next day
    with mytvonline2 no problem but now only what is happeing at this moment i can record.
    if i use the record button nothing pops up if i use the epg.
    Yes in both epg`s (the one with all channels and the one of the cannel )
    If i use the enter button in rhe groeps epg i can program but only for next dat
    In the channels epg i can NOT program.
  • Do you have epg under the guide button?
    If so you have to navigate to the programm you want to record,and press OK button,a menu should pop up where you can set up either a reminder,a recording or add to watchlist,and save this.
    You can check this in mol3 menu under scheduled recordings,so do not use the recording button for scheduled recordings.
  • this is NOT working in the channel epg only on the group epg.
    and the z11 only gives group epg for 24 hours.
    Dont say thats a problem with my provider because my z10 shows epg for 7 days.
    The channel epg is showen for 7 days but je can Not record there not with the ok and not with the record button.
    So how can we solve this
    Chris
  • I fully agree with you,i also have 24 hrs group epg with the z11,wheras with the z10 i have epg for 5-7 days,so there must be some future update to solve the problem!
  • You have 24H EPG on your Z11? I only have 4 hours!
    And me 2 I have a z10 with same provider and it give me 6 days EPG (MAC)
