MOL1 stuck on "cancelling connection" (resolved... I think!)
  • Greetings all.
    This is an odd one, and infuriating. :angry_face: ... for the moment only, hopefully! :crossed_fingers:
    I have a provider/portal I haven't used on the Z7+ for a while, and I'd forgotten that I needed to update the URL. When I tried opening it, needless to say, it wouldn't connect, and when I hit exit on the remote, it showed "cancelling connection" as expected. Unfortunately it hangs at this point.
    If I try force stopping MOL in Android settings, when trying to reopen MOL, it tries connecting to this portal again, and hitting exit results in it hanging at "cancelling connection" again... so you can see the problem: I can't use MOL at all at this point! :confused_face:
    Any suggestions? Restarting the box results in the same issue as force stopping it in Android settings, so right now I'm SOL with MOL... :winking_face:
    Needless to say, the Z7+ is updated to the latest firmware and version of MOL.
    Thanks in advance! :grinning_face_with_smiling_eyes:
