hi i just bought a formula z11 pro max
can anybody tell me if i was to buy a sandisk usb 3.0 32gb usb stick
would i have to format the stick to be able to record on or is it just plug and record using apps mytvonline 3 and tivimate thanks ![]()
Yes always format to NFTS,read in article section "How to format....etc"
You can do this on your laptop using Rufus tool to format ![]()
hi ive just been on the internet
i notices a hard drive 1tb
hard drive they recommend this drive for formula z11 pro max
it says its already plug and play
already formatted in ntfs
would this be plug and record straight away without formatting with rufus
will it detect drive straight away
also i was reading that the sandisk 3.0 is already formatted should then detect drive straight away
or are there any formatted drives that anybody can recommend that will be automatically recognised on z11 pro max
without needing a laptop and formatting with rufus
If they say so it will,but you can buy 1tb ssd or hd,from prices between 30-60 euro online just about everywhere!
You can connect the hd via a usb port (2.0 or3.0),then restart your box once.
Go to mol3 menu>settings>DVR settings and set the hd for recording and timeshift.
Its ready to use! ![]()
I f you read article on "How to format...etc""
you would know by now that formuler boxes are supported by FAT32,NFTS and exFAT formatting,NFTS is however the preffered option,according to SAM,for obvious reasons
what is the biggest size drive you can use on the z11 pro max
Basically there is no limit,you can go up to 4tb for external hd,but this will cost you!
For basic regular recording 1tb is more than enough,and you will also delete recordings,i guess?
The Toshiba 1 tb looks as a good choice pricewise and the fact its already formatted too NFTS,i recently bought an Intenso 1 tb hd and its superior too ssd or USB stick,but its FAT32,so you have to format it yourself on laptop
Make up your mind and go for 1 or 2tb external hd,shop around on internet some more,i must say the Toshiba and Intenso are both compact and hard plastic case fitting well esthetically with z11 box.
If you reveal what country you live in other people may direct you towards the best shop and price. ![]()
