solution to fix the problem of movies freezing
  • Hello, I have a formuler Z10 SE. When connected directly to the Ethernet port, I still have problems playing movies. Often the screen remains blocked.
    My modem is a 1GB but the ethernet port is limited to 100M and with WiFi I receive 75M. Question. if I use the USB port can I receive my 1GB? If not, do you have a solution to fix the problem of movies freezing. THANK YOU
