HDMI Video Range
  • Hi there. My new Sony Bravia TV has a HDMI Video range setting with the options Auto/Full/Limited.
    They say to match to whatever my external device (GTV) is set to so as they both match. I've looked but can't find it on the box.
    Can anybody tell me if the GTV has this setting and if so, if it can be changed to match the TV ? Thanks.
  • Hi,i don't have a GTV,but for a Z11 it would be: Home menu>settings>device preferences>sound and display>set resolution
    Maybe you can find something similar on your GTV?
    Hi there...yes, I have those settings on my GTV, but I don't see any mention of whether the GTV box's HDMI video range setting is Limited or full. Sony say to set your TV to match your external device's HDMI video range setting.
  • Hi there...yes, I have those settings on my GTV, but I don't see any mention of whether the GTV box's HDMI video range setting is Limited or full. Sony say to set your TV to match your external device's HDMI video range setting.
    Maybe you should have a look at YouTube: Doc Squiffy and Sony Bravia tv,there are some interesting tips to be found for your issue:winking_face:
