Posts by Lucky13
    Yes I know that. Some ISPs block them by name, I usually ping the name and then I get the IP address instead. And I always use GOOGLE dns.
    But it would have been good if in MOL3 you could change the portal address and leave the other properties intact. I hope my request reaches some developer.
    svejoh
    I can tag someone. So that the person from the company can read your wish direct. But it's up to them, what and when they do with it...
    ...maby soon, maby not, maby someday🤷🏻‍♂️🤷🏻‍♂️
    Anyone in contact with the developers of MOL3?
    A suggestion for a change in the next update. In the content manager/content sources where you have your IPTV portals. If you need to edit a portal address (only the portal address all other account information as before), when you then select update, there will be a new wizard and a new account. All favorites and history will disappear.
    I have a provider that changes the portal address quite often for some reason. Other IPTV apps can easily edit the portal address without losing favorites etc. but not on MOL3. Should be an easy fix to fix.
    mvh
    svejoh
    That the portal address changes is because a lot of dns/url's/portals are being blocked due worldwide laws.
    Thanks. Just an FYI: A competitor's knockoff device has it working flawlessly.
    It's not really a deal-breaker, but it would be very nice to have.
    I'm rooting for Formuler and am willing to be an alpha or beta tester, though!! :smiling_face:
    Thanks again!
    Beta can be for everyone who uses the code 1339 in software update on the Z12.😃
    If beta is available you see it after typing the code and it will be announced on the forum.
    Greetings to one & all, How often do you get software/firmware updates from the Formuler team re Z12 Ultra Thanks J
    The z11 got at the beginning many updates. Some monthly, some longer.
    The Z12 got also updates. But they do it this time the other way.
    They don't make this time small updates, but a hughe big update is coming with many fixis in one time.
    The cons with big updates, the users needs to wait much longer, and have longer there bugs.
    I think by introducing a new product to give them small updates the first weeks/months. Then big updates. But that's my opinion.😉
    Now we wait since february i thought for the new BIG UPDATE. If have no errors or bugs with my Z12 box. Some users have. It's long waiting then but it's coming.
    I hope i comes this month, but because it's big update, it takes time to fix all in once and testing...
    also hollidays the had begin this year so it comes all together.
    Still hoping it comes next week for the user that experience bugs👊🏻🙏🏼
    Goodday my friend
    That’s not correct. It was there over the last year on mytvonline3 before the most recent update. It was convenient and worked well which is why I was disappointed to see it disappear with recent update
    I'm sorry, but i hardly believe "refresh" was in your Mytvonline3 menu.
    It was never there, not on mine Z11 pro max bt1 and also not on Z12 ultra.
    Only in mytvonline2!
    I think you ment mytvonline2 my friend.
    (But i hope they add it in future like in mytvonline2)😃
    Wish you a goodday.
    It's not working, and even if it did, would I have to do this every time the Formuler wakes up from sleep?
    That's not normal.:frowning_face:
    No it should be saved.
    Check with your tv remote (not formuler remote) in your tv settings at screen/image setting or so that aspect ratio is original or 16:9
    And search for a zoom/scanning option in your tv settings! Turn that off or on. Zoom function can also have other name on your tv. Play with the zoom/scanning options.
    I have a lg tv, and turned "scanning" in screen settings From automatic to ON.
    At some tv's it needs to be off and or automatic. So search that option and play with it. Then it should be solved.
    Which brand tv do you have?
    Hi lucky133, I am aware of how to manually refresh based on your suggestion but has the “ refresh now” button/option been removed directly from the menu? It disappeared after update and content is not automatically being updated even though it has been set to do so.
    If that's so, make backup of mytvonline3 on usb.
    Uninstall mytvonline3
    Restart box
    Install mytvonline3 via Market app
    Restore backup.
    The refresh should be back in the Contentmanager.
    (Note: refresh was in mytvonline2 menu. In MyTVOnline3 they put in in the Contentmanager section)
    Can't find what you mean. Have you got a screenshot of what you mean?
    The steps should be (if box is blocked by provider):
    Please check following:
    At the home screen open the Command Center by navigating to the "gear icon" in the top right of the screen. The "System Info" is located on the second page of the Command Center. If molcfg installed, you should see "Check for configuration update" -> Highlight without pressing OK -> now press the 0 (zero) button 10 times on your remote (please count). This will perform a factory reset and remove the block.
    If you can't find "check for configuration update" then it's not blocked by a provider.
    Then wait for SAM or someone else for more info about error code.
    What i found i my first post on google should be the error code.
    How are you connected?
    Macid (stalker) or Xtream codes? url, username and password?
    https://www.youtube.com/watch?v=PVMeEBnGsiU
    I made a short video; you can clearly see that the image is shifted to the left. I have to restart each time for it to return to normal.
    On your tv the "ZOOM" function is active. Deactivate zoom in image settings from your tv settings.
    Or change the "screen position" on your box! (Simple way)
    Go to settings like in your movie, sound and image, screen position, zoom out screen couple times, mostly till 92 or 90%.
    Goodluck my friend.
    P.s: if you figured it out, please delete your youtube video from youtube😉
    Samsung T7 ssd
    SrJabardo
    November 2, 2022 at 8:33 PM
    I Think this is the answer to my problem. Think the box is stolen. Hope that formuler can give me some answers.
    When i know the solution i will type and reply it here.
    Can you find maby in android settings at device Preference and or in system settings something like "configuration update"??
    If yes, select/highlight it and press 10 times on 0(zero)
    It is a formuler fault, on my z10 i haven't got any problems. The fault starts after mytvonline 3 is installed after reset. At that moment there is still no iptv provider installed. I have used the z12 since februari and there where no problems with it untill yesterday.
    mytvonline3 installed and the popup block comes up? And no iptv provider added. Strange.
    Did you bought box at a iptv provider or (online)store?
    It's not a geoblock...
    Srange,because i am having one provider in common with Lucky13,and epg is loading without problems,lets await Lucky133 testing on his side.
    Will test it this afternoon my friend. First eat and check then the epg.
    But like our friend badmad04 said, yesterday nothing and today.
    And i had it yesterday evening with all my 5 providers. No epg. Strange on all 5 together. But like i said, will check this afternoon.
    Goodday my friends
    "Hello, I have a Formuler Z11 Pro MAX. Everything was working perfectly until I unlocked the portal in the system information by entering '000000'. After doing that, I had to enter the URL, login, and password.
    Everything else works fine, but I can no longer load the EPG. I left it on the default settings. I’ve tried everything: clearing the cache, loading the EPG, and refreshing, but nothing works. In the portal settings, no date is displayed for the EPG, and when I try to force an update, it fails to load. As a result, all channels display 'No Information'. I have to go into the full EPG menu just to see the program listings."
    Oh yes, I've already cleared the caches, performed a factory reset, and all of that... but still nothing works.
    I also tried using a 5G hotspot from my phone, but it didn't work. However, on the Smart Pro app on my phone, the EPG displays correctly for all channels. Is this a problem specifically with MyTVOnline 3
    You posted in wrong forum my friend.
    can happen.😃, no worries
    Anyway i saw yesterday evening that i also didn't have EPG.
    I use vpn, will have a look today and try to find out what problem is.
    But internet is out here at the moment, so can't do anything yet...
    It's not on your side.
    Goodevening,
    I hope that somebody can help me. I use a z12 ultra since the beginning of februari but since yesterday it says this device is block. I factory reset it and it worked again but today again it says device is block. I already made a ticket to formuler but they are not helping and saying that i need to contact my seller. It is not possible to contact the seller because i bought it on vinted and the seller is not on there anymore. The box was sealed and new.
    Greetings and a nice evening
    Marc
    Do you have installed the portal on more boxes?
    Based on Formuler support forums, the "208793b" error is likely a typo or variation of standard network connection errors.
    Here are the troubleshooting steps to resolve connection and server errors on Formuler devices:
    1. Check Provider and Credentials
    Invalid Credentials/Account Expired: Contact your IPTV provider to verify your subscription is active and that your credentials (username/password) are correct.
    Invalid MAC Address (Code 8): Ensure your provider has the correct MAC address for your device.
    Single Portal Usage: If you have multiple services, ensure you are only connected to one portal at a time, as they may conflict.
    2. Network and Connection Fixes
    Restart Network Equipment: Unplug your modem and router for 60 seconds, then plug them back in.
    Toggle VPN: If you are using a VPN, try turning it off, or conversely, try enabling a VPN to bypass potential ISP blocks.
    Use Ethernet: Switch from Wi-Fi to an Ethernet cable for a more stable connection.
    Disable IPv6: Disable IPv6 in the Android settings, as this can cause connectivity issues.
    3. Application/Device Fixes
    Refresh Content (MYTVOnline): Go to Menu -> Content Manager -> Data Sync to refresh your playlist and EPG data.
    Clear Cache: Clear the cache for the MYTVOnline application.
    Why would the MyTv app on both my z11Pro continuously need to be tweaked and played with to have it show live TV for 5 minutes, stall out (buffer), maybe keep playing or just decide to show a black screen. Internet connection is fine (+200mbs), box will do anything else online, just not have any kind of connection for the MyTV app.
    I have cleared the cache, unplugged the z11, reset the router, set the DNS to Quad9. This is after reseting the entire box and starting from scratch. I just want to watch live TV with some kind of reliable service.
    Maby bad provider or your internet is by internet provider downgraded due iptv streaming. (Spain, italy, france)
    Search google for free test.
    No names on forum.
    Do you use vpn?
    Try nordvpn with obfuscated servers!
    Amazing. 🤩 but I heard there is till problem with Netflix is that correct? In Netflix only like 720 p or something like that. Can you confirm this?
    I can confirm yes.
    Netflix is so stupid to don't give formuler boxes license.
    So it won't work. It's due Netflix, not formuler.
    In the market app you can download netflix and control it with a mouse and keyboard or so. And yes is 720p. Not hd.
    But it's not a big problem. The last 15+ years all tv's are with netflix on it.
    And all almost all people bought the last 15+ years a smarttv so has netflix.😃
    I have a question. Is it possible to watch 4k on apps like Disney plus or Amazon? On Formuler z12 ultra?
    Yes, my tv supports 4k, dolby vision, dolby atmos and if i watch as example with Disney Plus the Titanic on the Z12 Ultra it shows dolby vision, dolby atmos and 4K.
    See images.
    I hope i helped you out.
    Goodday my friend
    I couldn't find anywhere to download the latest firmware image for this player.
    The built-in software update app failed on all my attempts to upgrade the system online.
    What can I do now? I signed up, hoping to get an answer.
    Please help, guys.
    Goodday my my friend,
    Mytvonline3 can you download via the software updater. If not maby there is a server problem and or the update server is blocked by your internet service provider.
    Try making wifi hotspot from your phone. Connect with wifi with box to your phone and try software update again.
    Or try first at ethernet settings in android settings changing to quad9 dns.
    Settings > Network & Internet > Private DNS > Private DNS provider hostname > Quad9
    Goodluck my friend.
    Is it possible to have a different trailer app in MOL3 than the one in the Market app? Trying to update to the latest version of SmartTube, but getting an error. Installed SmartTube manually from their site, but it's a different package name, so I can't choose my manually installed SmartTube app in MOL3, it just redirects to the version in Market.
    Should come in next mol3 update.
    Due signature was stolen from smarttube, they made a new signature and gave the smarttube app a new package name.
    I got info from F_Peter begin this year, that it should be in next mol3 update the new smarttube so you can choose the new smarttube.
    Maby you can try TizenTubeCobalt and or newpipe.
    But i thought it couldn't be choosen in mol3 (yet)
    TizenTubeCobalt:
    https://github.com/reisxd/TizenTubeCobalt/releases/download/v1.0.8/cobalt-arm.apk
    Newpipe:
    https://archive.newpipe.net/fdroid/repo/NewPipe_v0.28.4.apk
