Posts by adrilang
    Sorry adrilang,i dont know what you mean with "Groups" button.I have set Favorites for every of my 3 providers,do you mean i have to go on live channel of every Provider and press the Groups button?,in order to separate the 3 Providers?
    Havent tried either your or la Praline advice on the matter,as i am currently recording a show
    What I mean by groups, on any live tv channel, doesn’t matter which provider, if you press groups button on your rcu it will open a menu which automatically separates content by provider.
    For example:
    Heading: Provider A
    Entertainment
    Factual
    Kids
    Heading: Provider B
    Entertainment
    Factual
    Kids
    So the first provider you setup in your content manager list and the relevant bouquets is what appears in your groups menu first and separated in order of content manager list.
    To the left of that are also icons which is basically a folder of some description so you can easily select the provider you want to use.
    If you have favourited your channels, you’ll only be able to view those favourites in one big list, it doesn’t appear to seperate by provider so maybe in that instance you create a favourite and rename by provider?
    I hope that explains better
    With regards to the UI, it’s a nice touch being able to change the colour theme on the Home Screen. I usually change the wallpaper for my own because the old theme was outdated but this has refreshed and its very Android TV…. Almost!
    For those that may not have seen, go to Home Screen and select settings then open launcher settings, select wallpaper and open gallery
    Your statement:
    “Another thing, when i am on apps tab, if i press en home button its happened nothing, should i come back to home tab?”
    I see what you mean, it could be nice to press home button and you go back to home.
    I have found that initially I was using direction pad on RCU (up down left right) to go back from menus to home, however; I press back arrow 🔙 and it does take you to home.
    You still have to blast through menus but it’s quicker than using directions.
    With reference to startup it will go to home option I’ve found.
    Settings icon in post 5 is not for selection, next to that is left direction arrow < so it’s basically saying there’s an extra setting so press left direction on your RCU to open next menu.
    In tv series or VOD menu, instead of pressing back button which as you say takes you back to live tv, press menu button on remote (3lines) and MTOL3 menu appears.
    Backup and Restore gives “Empty storage “ message. Reformated the SD card but got the same message.
    It was working fine before beta.
    I did backup and restore using USB and it works fine so could be something affecting SD card only?
    I did notice then from first install of beta, I went into MTOL3 and DVR options and noticed the usb had a line through it so I selected it again to choose the usb I wanted for storage and was no issue.
    So although this isn’t the same issue you described, it could be something to consider because as this is beta, some things can affect others.
    I wouldn’t think it would cause your issue in this situation but even still it’s something to look out for just incase
    For sure this is a provider issue, there something in the panel coding that’s changed preventing MTOL reading the playlist.
    Same issue related to if it connects via mobile instead of wifi and then stops using wifi and or Ethernet
    Should be a quick fix but must be done from provider / panel supplier side
    The refresh content jst dosent seems to do anything ,so what's the purpose of it?could Sam explain? Cause I still need to go into content manager every time and manually update the epg,I find a extremely annoying feature and I not sure of it purpose
    Refresh content is separate from EPG.
    It’s to pull new content that the provider has pushed to your subscription. Some providers update once per day but others multiple times per day.
    If you are having an issue with epg, have you set your epg update interval?
    Mine is automatically set to update every 24 hours and I find this does work and haven’t experienced an issue.
    To locate this option, open content manager and select the subscription you want to change, click the edit icon and you’ll open a list, change your time in “EPG UPDATE INTERVAL” and the update once done.
    If you manually refresh you will get a popup when it has refreshed in the background asking if you want to refresh the playlist. Should be no need for popup as if you manually press refresh in the menus, you want to refresh now, so no need for confirming it again.
    Sadly this is not what we req as we still have to dig into the menu system to manually update.. Well well.. We need Refresh button directly when pressing menu, like in Mytvonline 2..
    As for manual refresh, I too hoped this would be implemented in the same way as MTOL2, 175N suggested it would be in this update although I’m unsure if he meant something else.
    I’m unsure what you mean “can’t create the name of into rows”
    Can’t you explain please and I will check for you to see if I get the same.
    If you mean when you create your own group, it is possible to change the name of that group.
    You locate the name and press and hold OK button and options appear.
    If that isn’t what you mean my apologies
    Hi, i dont know how to implement the separate listing of Providers (3 in my case) so that they work as separate Portals,as mentioned in changelog MOL3,first line?
    On any live channel press the “Groups” button.
    Consider if you have pinned and re ordered bouquets the will appear only in “My Group”
    If you don’t do the above then content is separated by provider
    You can always create a favourite group and reorder that way and works great
    Hello
    I'm 2 months into my Formuler Z11 Pro Max journey, having finally switched from the Z8
    I use MTOL3 but when I switch the box of using the standby button, the box automatically resumes MTOL3 when I turn the box back on. This isn't a startup issue (there is not startup apps selected), more of a standby issue.
    Is there a way to stop this automatic resuming of MTOL3 when starting with the standby button? Or alternatively any way to re-code the standby button to be a compete shutdown?
    Formuler Home Screen > Quick Settings menu > Power mode > Power off
    That path will set to power off when you select power button on your remote so the next time you press it, it will power back on.
    If as you’ve confirmed that the startup app is not set, it should simply power on to your Home Screen.
    I hope that helps
    Then,you are one of the lucky ones,on 3 providers (XC) only 24 hours epg:frowning_face::frowning_face:
    EPG could be panel / provider related which is why it’s taking a while to resolve.
    Not suggesting an issue provider side but it could be the scripts are different to others that are working so it’s a matter of Formuler devs wading through I guess.
    Think Sam mentioned before that main guide in MTOL3 pulls differently to other version(s) so I guess it’s only a matter of time before it’s sorted.
    Edit to the above post!
    I'm now seeing EPG across both provider A and B beyond 24 hours.
    4 days for A
    5 days for B
    So for me, epg issue is no more.
    Hi,as far as i understood previous post by 175n,automatic refresh is to be introduced in upcoming update,end of this month,meaning you no longer have to set refresh in CM,but it will be done like in mol1&mol2 automatically.
    There must be some confusion because only Z11 has auto update currently which is set by one specified time interval by the user.
    I think he must be referring to manual refresh option in MOL3 which may be the same as MOL 1 & 2 whereby you press menu button and refresh option is there instead of going through multiple menus as currently in MOL3.
    If it’s meant by automatic update when device powers on in first instance then that was always available in MOL1, 2 and 3
    Unless he is referring to an enhanced auto update feature in MOL3 from what is currently available
    I wonder if your provider has taken the feature away server side and no longer offering playback?
    Currently running latest update and I see epg improvement, partially.
    Main guide
    Provider A - 24 hours epg still
    Provider B - 5 days epg
    XC API connection
    Each connection with a different panel
    Consider the update was not advised as anything epg related and I haven’t checked on epg for a while so it could have been like that since the last one
    Either way, I see what I see :thumbs_up:
    I have no Z11 yet, will come in a future update an automatic "content refresher" like in mol1 and mol2?
    I mean: when you start mol3 everything loads automatic, channels, epg and vod? Just like mol 1 and 2. Cause many people talk always about the "content refresher" and how many times etc.
    Have a nice day everyone.
    MTOL3 has an automatic content refresher, I personally do not see what people mean that it doesn’t work.
    For me it does work and has worked since the start.
    Content refresher automatically refreshed content for me at the time I set which is 11:00am
    If I turn on my box at 11:15 as an example the box powers on and then when loading MTOL3 it takes a little extra time but once loaded it notifies me content refresh complete, so it does work.
    However; it only does that from the time set. Maybe in the future it could do it at more intervals.
    If the user wants to manually refresh, that too is an option however there’s several more steps to do this which is long winded but I expect it’s because the auto refresh feature is present so the manual refresh is kept out of the way or so to speak.
    There is an afterthought with this process because many users experience multiple content updates each day from providers so I guess three options for Formuler to consider:
    1) Manual refresh in same location as MTOL2
    2) More time intervals for automatic update
    3) Both the above.
    But overall the auto refresh and manual refresh are
    Present in MTOL3
    For portability the Z Mini is excellent, overall it’s really good for such a compact size, the only caviat is the large RCU.
    Don’t get me wrong, I like the Formuler RCUs, they’re perfect for more permanent TV solution however; as the mini is portable, it would be nice to see a more compact version of BT1. Same features or as close as possible but less footprint.
    Then it really is truly portable.
    Quite sure the Z mini will be very popular if not already.
    The worlds most bought streaming stick will be heading to its own OS soon and moving away from Android so unless app developers bother with new apps especially in the IPTV space, it’s a prime opportunity for Formuler to take those users :OK_hand:
    I’ve been through this thread and can’t see anything about what I’ll post so here goes.
    I actually have 3 Z11 pro max’s in use but I’ve
    Just setup a Z mini because Itl be great for when I travel and seems an excellent little device.
    Perfect addition to the Formuler line up.
    Love how a feature that’s been requested so many times has appeared within MTOL3 on the mini.
    For those wondering, when you have multiple providers channels in a list, you can actually select the name of the provider you want to view.
    So the requests were a collapsible folder when you press groups and this is a similar thing Formuler have come up with and it’s excellent! Very helpful.
    Now I have just one “negative” about this feature or it may have been missed by the devs or it’s deliberate but I’ll say anyway.
    If you have pinned bouquets and also put them in an order to your preference, I notice the feature mentioned above will show no channels when selecting a provider, however the pinned groups will appear in the main groups heading.
    If you don’t use the pin option, they appear as normal per provider.
    Consider pinning bouquets is done only for reordering them so it’s a necessary feature.
    Hopefully this piece can be looked at?
    Apologies if that isn’t the best description above, those with a mini and multiple providers will understand what I mean.
    Apart from that, excellent device!
    Unsure if this was ever mentioned before but if not and you’re interested, here’s a very quick and easy way to speed up menu transitions.
    Lightening fast, I think in comparison to standard settings.
    1. Formuler Homescreen
    2. Settings > device preferences > about > build
    3. Select build 10 times to enable developer
    4. Go back to device preferences and go down to developer options
    5. Go down to window animation scale and set the following:
    Window Animation Scale set to OFF
    Transition Animation Scale set to OFF
    Animation Duration Scale set to .5x
    Now exit developer options and test
    Should be the same menu path across the Z series devices I expect
    Also my initial regarding the epg was the fact that I'm having to manually update it every time I turn the box on,
    To assist with automatic update of epg do the following:
    On any live channel
    Select menu button on remote (3 lines)
    Select content manager
    Select content sources and choose your subscription
    Then across where you see log in details etc, above are some icons. Choose EDIT (looks like a pencil)
    Then go to epg update interval and change to 24 hours or whatever you find suitable.
    That should then automatically search for epg when that time hits.
    select update to save it.
    Overall it won’t change that you’ll only get 1 day epg but it should refresh it automatically to save you manually doing it.
    It works well for me so hopefully it does for you also.
    This has never happened to me before on any updated but after having a 100% fully working z11 after the update this morning I have very little working correctly.
    Slow loading, no live tv channels, no epg and when trying to access the home page get invalid format. I did a power cycle and proved the box to he working on vod and tv series plus home page again now but terribly slow response to remote control.
    Oddly have some random Indian channel working though ??
    I have another box on the same service but not the latest update working perfectly so not the supplier, whats gone wrong lads...wish I had not done the update now as did not back up as always worked first time on previous updates?? HELP
    On that live channel, press menu button on your remote control (3lines)
    Go to content manager
    Got to content sources
    Select your subscription
    See the icons at the top, locate and select the one that says refresh
    Wait a couple of mins whilst it reloads the subscription
    Hopefully that sorts it for you
    You say you dont have issues with epg,but in earlier postings you wrote "epg on XC limited to 24 hrs" does that not apply to you or are you on MAC-ID connection?
    Or do you have a "special" itpv provider? :winking_face:
    EPG for 24 hour isn’t an issue for me as I don’t schedule recordings etc.
    My posts primarily were for those who had no epg at all.
    I think the person above was also suggesting they had no epg, unless I read the post incorrectly.
