Unsure if this was ever mentioned before but if not and you’re interested, here’s a very quick and easy way to speed up menu transitions.
Lightening fast, I think in comparison to standard settings.
- Formuler Homescreen
- Settings > device preferences > about > build
- Select build 10 times to enable developer
- Go back to device preferences and go down to developer options
- Go down to window animation scale and set the following:
Window Animation Scale set to OFF
Transition Animation Scale set to OFF
Animation Duration Scale set to .5x
Now exit developer options and test
Should be the same menu path across the Z series devices I expect
