Formuler z11 pro only showing 24 hours of epg
  • The simple answer would be:NO
    However if you switch to MAC (Stalker) connection,and change epg mode to alternate you will have 5-7 days of epg!
    Edited once, last by henkie (April 22, 2024 at 10:18 AM).
    Thanks for the reply but that doesn't help me when I have a xtreme type service. Trying to do recording 2 days in advance when I leave on weekends. Hard to do with a 1 day guide.
  • Thanks for the reply but that doesn't help me when I have a xtreme type service. Trying to do recording 2 days in advance when I leave on weekends. Hard to do with a 1 day guide.
    I am in the same boat,also XC conection on providers,and no option to switch to MAC,unfortunately there is no solution to the issue and i doubt it will ever come:frowning_face:
  • Currently running latest update and I see epg improvement, partially.
    Main guide
    Provider A - 24 hours epg still
    Provider B - 5 days epg
    XC API connection
    Each connection with a different panel
    Consider the update was not advised as anything epg related and I haven’t checked on epg for a while so it could have been like that since the last one
    Either way, I see what I see :thumbs_up:
  • Edit to the above post!
    I'm now seeing EPG across both provider A and B beyond 24 hours.
    4 days for A
    5 days for B
    So for me, epg issue is no more.
  • Then,you are one of the lucky ones,on 3 providers (XC) only 24 hours epg:frowning_face::frowning_face:
    EPG could be panel / provider related which is why it’s taking a while to resolve.
    Not suggesting an issue provider side but it could be the scripts are different to others that are working so it’s a matter of Formuler devs wading through I guess.
    Think Sam mentioned before that main guide in MTOL3 pulls differently to other version(s) so I guess it’s only a matter of time before it’s sorted.
