How to create mixed playlist and autoplay at startup
  • Hi all,
    I just bought a Z10 SE for a museum but I'm finding many difficulties to do thing I thought was basic. I never tried one before.
    1) I would need to create playlist with images and videos. I tried to install also VLC, but it's a limited version and it doesn't work perfectly. The images work good, but not the videos.
    2) I'd like to use a pen USB fro the media, but I cannot find the method to automatically start the playlist/presentation at the startup of the Z10. Is there a way to do that?
    Have you any suggest?
    • Model: Z10 SE
    • Firmware version: v10.10.54
    • Box connected with: Epson Projector by HDMI
    • Did you factory reset your device? and when?: It's new
    Thank you
  • You can set the startup app in the Launcher Settings.
    The app you select as the startup app will need to be able to play a list of videos and photos in a loop.
    3rd party app recommendations are outside the scope of support on these forums.
    Search google and ask Gemini/ChatGPT for suggestions.
    One keyword you may find useful in your searches is "kiosk"
