VOD
  • Hello..i bought 2 z10 that were pre programmed with mytvonline2. Was working fine then it was unusable..kept getting and error. I Had to goto build and press 0 10 times to reset the box... After that I had an update...did the update and when i go back on mytvonline2..the live part is fine...but there is next to nothing on the VOD,,,just a few programs...How do I get all the movies back from when i first purchased the 2 boxes.. Please and thank you for your responces
  • You need to contact your seller or service provider with questions about contents. Formuler only manufactures the devices - it doesn't have anything to do with the contents.
