MYTVOnline 2 fails to properly detect the stream’s actual frame rate
  • Since switching to the Formuler Z10 Pro Max, I’ve been experiencing constant motion blur during live broadcasts of a particular sport — both on 25 FPS and 50 FPS streams.
    What’s especially noticeable is that when the stream is technically sent in 25 FPS, MYTVOnline 2 incorrectly detects it as 50 FPS. In these cases, the blurry image appears consistently.
    However, with a proper 50 FPS stream — which the app correctly identifies as such — the video plays smoothly, with no motion blur.
    My TV output setting is set to “Auto”, so the box should ideally adjust its output framerate to match the stream.
    This leads me to believe that the issue is likely due to a bug in the current version of MYTVOnline 2, specifically related to incorrect framerate detection for 25 FPS streams, which results in poor motion handling and visible blur.
  • What’s especially noticeable is that when the stream is technically sent in 25 FPS, MYTVOnline 2 incorrectly detects it as 50 FPS. In these cases, the blurry image appears consistently.
    And if you turn AFR off?
  • This won’t fix the problem, because I only enabled the “Auto Frame Rate” feature for live TV today — and the issue with the blurry image already existed before that, when the feature was still disabled.
