I have an Formuler Z11 Pro Max in the bedroom and one in the livingroom, the issue is that epg will not load on the one in the bedroom.
Tried to clear and update epg, factory reset, even tried a whole new line from the provider. Nothing works!
Tried the line on tivimate it works there.
On my 2nd Formuler z11 pro max in the livingroom everything works fine. I changed the line from bedroom to livingroom box and it works.
Have tried everything, what can i do to make it work, i think its the device problem. Plz help!
