can't open google playstore and netflix
  • Hi there,
    since a couple of weeks i can't open the google play store app any more on my Formuler Z10 Pro Max. So also i can't update my apps so netflix en a couple of other apps aren't working any more. Anybody has an idea to fix this?
    Greets
  • Are you seriously 120 years old?
    Try going into Homemenu>settings> Apps.>go to Playstore and Netflix and see whether they are in the App list,might need to go into "show all Apps"
    After go to apps choose system apps and search for google playstore.
    Click then "delete updates" and restart box
    After restarted bix open playstore again and you will see its an older version but it updates itself the same day or week.
    Goodluck andet me know if its fixed.
    henkie comon my friend, 120 years hahaha. Just an fake birtyday my best forum friend.
    Edited once, last by Lucky13 (June 26, 2025 at 12:20 PM).
