My program are lagging on some network! US networks
What can I do My internet speed is at 865Mbs
Someone else having this problem got it for a month now though a update would come out
Thanks for your replies
Can be provider related. Some countries are laggy. Try it also on other app like smarter or so.
Or try use a good vpn.
Using Nord VPN provider said try turning it off no changes! Provider is looking on is side doesnt seam to see the problem !
Will try smarter today
Though had touch a setting in the box
Will try smarter todayThough had touch a setting in the box
Your iptv provider needs to know that you use a vpn.
So tell them you use a vpn.
Close mytvonline good if you test it on the box. If you have one connection or 2 boxes with same account it wil be laggy.
One box/app at the time to play iptv, or you have a 2 connection subscription, but i don't think so.
Told provider what VPN im using
Now he wants me to empty MOL2 app cache refresh restart MOL2 refresh EPG
Lets see if it works
Got only one box running
Put UTC and removed the EPG off set now guide is working good its was set that way before do t know why it buged
its lagging on US channel mostly
Well put my Smarter TV in my Formuler and wasn’t better
Installed Smarter in My Roku Tv no more lagging but can’t make a favorite list
So the box is the problem
Will try to plug with etheret cable tomorrow to see if Wifi board is dying
Does anyone know a app that can work with my Roku remote to build a favorite list?
Thanks for all who commented
Hope its not the box that isnt supported anymore!
Display MoreWell put my Smarter TV in my Formuler and wasn’t better
Always use minimal a cat 5e or cat 6 ethernet cable.
