Is it possible to install mytvonline3 app on Z10pro max?
Formulet Z 10 pro max
- Apps
- Z10 Pro Max
Eli Kramers -
December 6, 2025 at 4:43 PM
No,
You need to buy a Z11 box (z11 pro max bt1 as advice.
Or the best of the best one of the moment.
The Z12 Ultra.
Goodday my friend
If you need anything else, let me know my friend.
Besides the models Lucky133 mentioned,you may also consider buying a z12 mini,also with mol3 and relatively cheap and portable when you want to take it with you on travelling.
But be aware that you need a usb to ethernet hub if you want to use no wifi. Ethernet cable is always stable.
So buying z12 mini and you want using ethernet. You need to spend extra money to buy an usb to ethernet hub.
Buy direct a z12 ultra and you are done.
Thks for yr answers But i already have also the Z11 pro max. I was wondering to update the z10 but if it is not possible . It is ok.
Correct my friend.
