SmartTube on Formuler Market (Formuler Z10 Pro)
  • Hello,
    There are currently two versions of SmartTube available on the Formuler market:
    1. Version 30.48 (last updated on December 19, 2025)
    2. Version 30.56 (last updated on December 3, 2025)
    Which version should I use now? Is the 'newer' version 30.56 recommended, even though version 30.48 was updated more recently?
    I have a Formuler Z10 Pro
    Cheers
    Pille
  • Doesnt really matter which version you choose,if there is a new update you will be automatically notified in the left upper corner:smiling_face:
  • Hi Pille
    After the info spread by the developer of SmartTube i uninstalled and reinstalled SmartTube twicefrom Market,up to now i have not encountered any problems,but if you are unsure choose your last option and install the.apk from their website,just to be on the safe side.
  • Version 30.40 works with trailers in mytvonline 3. So also in mytvonline2 if implemented.
    Version 30.56 is the safear version with new signature
    The creators signature of the all was stolen, so ha made a new signature for his app.
    So 30.56 is safer and can be used as tputibe on your box.
    Only not for trailers in mytvonline 2. Therefore needs to come an update for mytvonline 2 so it uses the newest version.
