Would like to use or force IPV6 in MYTVOnline3
  • Hello, is it possible to have MYTVOnline3 use IPV6 to connect to my provider? I have a fully compliant IPV6 isp and network, and my provider resolves IPV6.
    My Formuler z Mini is connected and has an IPV6 address, it's working in the OS, but MYTVOnline only connects using IPV4.
    Verified other ways that IPV6 should work, so I think it's a limitation of MYTVOnline, or a setting I'm missing.
    Thanks.
    Thanks.
    Did it not work?
    The switch is on at internet settings? But you say mytvonline3 isn't future proof, cause it won't work with ipv6?
    Maby it's your iptv provider what isn't future proof yet? Did you try already a free trial at other provider and connected with the iptv server with mytvonline3?
    I can't almost believe it, since 2017 or so we have already by isp ipv6 rolled out.
    I will hear what they say from Formuler out. I'm curious now.
    F_Peter  SAM
    Edited 2 times, last by Lucky13 (January 6, 2026 at 9:50 AM).
  • I can see on my provider dashboard how it's connecting so I'm confident it's mytvonline3 limitation. When streaming it shows the IP it's using so I can reliably see from their end if it's using IPV4 or IPV6.
    I have tested TiviMate on the same Formuler z Mini box and confirmed that it connects with IPV6. So the Formuler box is connecting and the Android system is allowing it. I'm not using VPN. I believe that just leaves the Mytvonline3 application.
    I will test it myself too. Try to do it within 15 minutes.
    I see only wan ipv4 yes
    Edited once, last by Lucky13 (January 6, 2026 at 7:03 PM).
