Programme freezing
  • Having problems with programme freezing on Formuler Z11 Max Pro. Have tried resolving with Broadband provider but no faults found. Info page shows good WiFi but low or no bars on signal strength. Have tried both WiFi streaming, ethernetand also Mobile phone hotspot. The display (Bars) show no different indication with only one or no bars. What is this telling me as watching TV is becoming very annoying? What can I do to help / correct the situation?
  • Welcome on Formuler forum my friend John.
    The bars upper right corner gives signal strength of the channel stream.
    But i have sometimes also 1 bar from the 3. But no buffering.
    Search good provider on google or so or ask friend.
    And ask free trail so you can test. Then you can see big differences between good and "bad" providers. Maby your provider is not buffer free. To less servers etc.
    Cause you tested it with both wifi's and ethernet cable.
